Westinghouse Notebook power supply
I have a westinghouse notebook. I have had it for about 1 year. I keeps shutting off. Even if I have the electrical chord plugged in all the time. The longest it stays on is 15 minutes. The power light keeps flipping from grren to orange. Is my power supply dying and where would I get it serviced?
  • rickhoying Mar 20, 2009
    Laptop runs fine for 12 - 15 minutes, then shuts off. I loaded Speedfan to monitor temperatures, thinking a thermal shutdown was causing the problem, but the Core and HD are running within parameters. Another possibility was an old graphics driver, but it is up to date. I took the back off and cleaned out the heat sink and fan area, but that didn't help. The only thing left seems to be the power supply, and I have no way of checking it without the help of a pro. Since it's a cheap laptop, I doubt I will invest more than about $50 in it. I'd rather find a good 2 year old IBM Thinkpad for $250. I'll let you know if I find the issue.
    Rick.
    Sergeant:
  • 349 Answers
If it is under a year old it should be covered by warranty,so contact the seller or manufacturer,
It sounds very much like a power pack is on its way out, and they are a sealed unit ,
try it in another power point. if power point is working fine, but you still have the problem,
and its over the warranty period.
take it to your local computer store and have them test it for you ,they will also be able to order one in and sell you a new one ,if it is the problem.
good luck with that
Terry
Posted on Mar 28, 2008
  • Anonymous Mar 28, 2008
    when i say take it to your local pc shop i mean the power pack
SOURCE:
Philips TV freezes or turns on/off continuously
please check on mains chord and plug or even better the plug itself by connecting another lamp to see it flickers meaning something wrong with the AC line in.
1.either replace mains power chord
2. also see solder connections inside TV that is if you know something about mains take care to switch of mains and disconnecting main chord
happy hunting
Sep 12, 2015 | Philips Televison & Video
Laptop neo b2240n just shut down and wont start up..
help plz.. Laptop neo b2240n cant open, but there is a light on power chord
Dec 26, 2012 | Computers & Internet
Westinghouse outdoor timer with 6 outlets instruction manual
1) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) After viewing link above, add a comment with clear detail about timer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 22, 2012 | Hardware & Accessories
My westinghouse 19H210S quit working 1 year 3
I also just changed the bulging capacitor and also it still does not work. Even though it was bulged when I tested it after changing it the capacitor tested normal. Not much help but clearly the 2200 capacitor is not the only problem.
Apr 15, 2010 | Westinghouse SK-19H210S Television
Power chord problem
(1) Does the machine work with the cord plugged, if so it is the battery or the charger circuit at fault
(2) If it does not work then there is either a break in the cable where it enters the plug which plugs into the back of the laptop or the power supply has failed
Aug 31, 2009 | Sony VAIO VGN-NR430E/S NoteBook
My lenovo it keeps shutting down
hi im josh in cebu phils. may i help you? Friend i encountered the same problem of yours before.and i was able to solve it. Friend the rechargeble battery/supply of your notebooks is the problem.change that with the new one. or before you do it try to see first if the connections are ok like loosening connection may cause these problem. dmage power chord may aslo cause or the socket of your note try to check if not loosen or weak or detached. good luck!
Feb 21, 2009 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
Guitar chords
Do you mean like that?...
  • CHORD A
E---|---|---|---|---|
B---|---|-x-|---|---|
G---|---|-x-|---|---|
D---|---|-x-|---|---|
A---|---|---|---|---|
Sorry if this isn't what you mean :) xxx
Jan 24, 2009 | Yamaha Electric Guitar
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
Open Questions:
Computers & Internet Logo
137 people viewed this question
Ekse
Alun Cox
