Question about Meco 5025 Smoker
I have a water smoke and don't know how to use it
My father in law gave me a charcoal water smoker and i dont know how to use it
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
The quick and short story is, fill the charcoal pan about 1/2 to 2/3 full of charcoal. Fill the water pan about 2/3 full of water and I add beer or whatever marinate I have left over. Spray PAM of similar item on your grills. Get the charcoal going, you need to try to regulate the temperature for 225 and maintain it for 4-6 hours depending on what you are cooking. You will need to reload the charcoal as needed to maintain the cook through out the period needed. I would start of with a couple whole chickens and put a digital thermometer in the breast. Cook till the breast reaches 170-175 and remove. Place soaked wood chips or chunks on top of the charcoal during the cook. The first hour it is important to keep some wood in there to get that smokey flavor. I use oak and Hickory.
If you really want to learn to cook good smoked foods, Google "smokering" and you will find a bunch of forums dedicated to the smoking foods and bunch of good people willing to help you learn.
Posted on Jun 21, 2010
I put the charcoal in the bottom bowl in the smoker. what do u put in the top bowl right above that? i am making beef jerkey
Hi there....the top bowl which is smaller than the charcoal bowl is primarily for water to keep moisture in the roasting environment while cooking..I don't think you want to add miosture to make jerky...I have a Ronco food dehydrator for that...I only use my smoker for slow cooking and roasting/smoking large peices of meat..I hope this was helpful.....
Sep 05, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
I have a char-broil smoker. It's not electric, though. It's a charcoal outdoor grill. I need to know how to use it. Got it at a garage sale and forgot the instructions the seller gave me. Any...
I'm not sure this is the same model you have, but it's the only one Charbroil now makes. In any case, most vertical charcoal smokers work the same way.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/06701289%20assembly%20manual.pdf
I hope this helps you. Enjoy your smoker and thanks for choosing FixYa.
Aug 16, 2011 | Char-Broil Electric H2O Smoker
We have a brinkmann smoke 'n pit charcoal grill $ smoker- the manual says to cure it- how do we do this and for how long? :-)
By cuing, they mean burning it for an hour or 2, before using it to grill or smoke food. Coat the grill grates with a light coating of vegetable oil, before firing up the charcoal. Maintain a temperature of 325 - 350 degrees F for half an hour with the hood closed and a half hour with the hood raised.. After that, the grilling part of the grill - smoker should be cured. The smoker part, other than cleaning, doesn't need much curing. As the temps for smoking don't exceed 225 degrees F.
Hope this helped you and Happy Grilling!!
Jun 28, 2011 | Grilling
I just got a Char-Broil H2O Smoker from a friend. I do not have a manual to tell me how to operate it. Also one pan is for charcoal and one pan is for water. Which pan is for which thing? One pan is solid...
Debbie, since you didn't have an Owner's Manual with your smoker. Rather than me go thru a lengthy process of explaining all there is to know and how to use the H2o Smoker.
Here's a link to the Owner's Manual, that you can download and print for future reference.
Hope this helped you and enjoy your smoker.
Jun 19, 2011 | Char-Broil Charcoal Water Smoker 4654301
Have charcoal grill/small smoker. burned the meat in the small smoker. Do i put meat on the grill side and use the small smoker for charcoal and wood chips only? my grill did not come with a manual
It depends on whether your trying to smoke the meat or grill the meat. You can't do both at once.
If you want to grill the meat, don't even fool with the smoker part. Put the charcoal in the grill side, light it and allow it to get white hot, before putting the meat on to sear it on both sides first, before moving it to a cooler part of the grill to finish cooking to your likeness.
If you're trying to smoke meat or whatever, you use only the smoker side for heat and smoke. By, usually using some type of hardwood, like Oak, Mesquite , Pecan. etc. However, the meat or whatever you want to smoke, goes on the grill side (No charcoal required under it), because smoking is a low heat (200 - 225 degrees F) slow process. Any where from a couple of hours up top 8 hours, depending on what and how much you're smoking. It's often referred to, as "Low & Slow."
Hope this helped you to better understand how a combination grill-smoker works. Once you do a little receipe research and get the hang of it, you'll really enjoy it.
Jun 18, 2011 | Masterbuilt Grilling
WHAT ARE THE DIFFERENT PARTS OF THE CHAR BROIL H20 SMOKER NOT ELECTRICAL
Most of the small vertical smokers will contain, a charcoal pan, a water pan, and grills. That is about it for internal parts. The charcoal pan goes on the bottom and the water pan will go above that and then the grills. I hope this helps.
Jun 20, 2010 | Char-Broil Charcoal Water Smoker 4654301
My smoker stopped smoking; the temperature is IDEAL
You will need to replenish the charcoal as it burns down. You can also add some soaked wood chips or wood chunks at the same time for additional smoke flavor. It you are using the water pan it would be a good time make sure it has plenty of water also.
Watch your temperatures and when you see it start to drop, add more fuel to keep the temps up.
I hope this helps.
Jun 06, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
How much wood do you put in a h20 smoker for ribs
Ah, the age old question. Basically the meat only absorbs the smoke for the first hour to two. This is when the smoke ring is created in the meat. I would use enough soaked wood to keep a slight smoke coming out for the first two hours. After that charcoal is enough in this type of smoker.
You can Google "smoking meat" and find tons of info and forums but be forewarned. You may get hooked in the art of smoking meat.
Apr 10, 2010 | Char-Broil Charcoal Water Smoker 4654301
I just got my charbroil offset smoker and i have
Use approximately 5 lbs of charcoal or a little more that a chimney charcoal starter and let it go grey and get your grill to the temp you are looking for then add the pecan on top of the charcoal in the fire box.
Feb 28, 2010 | Char-Broil American Gourmet Grill
Got my brinkmann smoke'n grill and need to know. #1 do i have everything i need and how do use it if i do.
if you have the smoker, charcoal, wood chips and water or another liquid you would like to use such as apple juice, beer, or brown soda.....then yes
Jan 24, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
Meco 5025 Smoker Logo
488 people viewed this question
Top Meco Grilling Experts
ray gallant
Tom Chichester
Are you a Meco Grilling Expert? Answer questions, earn points and help others
