Question about Kenmore 44832 Front Load Washer
Kenmore Elite HE3 44832
Is there anyway to reverse the door on this machine? it open towards the left and is very inconvenient for us becasue our dryer has to be on the left. so we pick clothes up over the washer door to get them into the dryer.
    President:
  • Kenmore Master
  • 2,651 Answers
You can only reverse the door on the dryer, washer cannot be switched, youll need to reposition the appliance if at all possible
Posted on Mar 28, 2008
Unlock door on kenmore elite 110.4996
turn the power off
and let the machine sit for 5 mins
if it still wont open then the door interlock has frozen up
and youll need to pry it open
best leave this too a tech
its a grim job anyway
and worse if you have no idea what to do
Feb 08, 2015 | Kenmore Washing Machines
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
The door won't open. There are no error codes displayed. I have a Kenmore Elite HE 3t.
open the bottom panel by unscrewing 3 screws. reach up towards the door lock and pull a level to manually unlock the door.
Aug 17, 2009 | Kenmore Washing Machines
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Reversing the Door
nope only the dryer doors are reversable..last washer to have reverable door that i know of was old neptune
Sep 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 110.4586 or 4587 door lock
probably door lock or door strike on door itself ..easy change pull spring off door boor roll boot out of the way remove screws holding door lock in place ..pull toward opening remove wire connections reinstall in reverse ..boot spring can be tough but no big thing
Sep 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer and dryer
The door can be reversed on the dryer but not the washer.
To reverse the washer, the door latch and wiring harness would have to be relocated, which is not practical from a manufacturing standpoint.
Post back if you have any questions.
Nov 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44832 Front Load Washer Logo
228 people viewed this question
Sal De
fordexpert
Robert Rankin
