Question about Aiwa AM-F80 Personal MiniDisc Player
Aiwa am-f5 display says no adj - Aiwa AM-F80 Personal MiniDisc Player
2 Suggested Answers
  • 1456 Answers
SOURCE: my screen says "no adj"
Hello
Check that the disc is inserted properly.Open the disc chamber and pull out the disc. Place the disc back in the unit and try again. Check the hold switches (both on the device and on the remote). If they are activated, the unit will not play. The hold switch on the device is located on the top right side. On the remote control, the hold switch is located on the left side. The internal lens may be experiencing condensation. Open the unit, remove the disc, and allow the unit to sit for a few hours to dry out.
If none of these options is working, try a system reset to restore all settings. Take a sharp object (such as the end of a paper clip) and stick it into the small "Reset" hole located on the back of the device. This should restore all factory presets.
Posted on Oct 07, 2010
Where can I get a replacement battery for my Awia mini disc AM F5 ?
The Aiwa batteries are hard to come by. I got rid of a lovely Aiwa pootable becasue the only battery available was $150. Many of the older models use rare batteries which are just not made anymore. You may find a NOS one for a high price on ebay or a used one with some life in it.
This is a sadsituation because they were great machines...
May 14, 2014 | Sony NetMD Walkman MZ-NF810...
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
Tv error codes
This problem has been answerd a few while ago.
May 17, 2013 | Aiwa Televison & Video
Radio display displays ADJ and won't operate
This is outlined in the owners manual please click here to download the manual
Feb 21, 2012 | 2008 Ford Escape
Wharfedale NE-571 How do i set the time on it i bought it second hand
Hold MEM/C/ADJ in power off/Standy mode until you see the clock display flash.. let go of MEM/C/ADJ using the forward/backward buttons above the volume dial select 12/24 hour press MEM/C/ADJ again.. you will see the left bank of digits flash.. press forward or backward to select your hour then press MEM/C/ADJ again set the minutes and then press MEM?C?ADJ again and your done!! ;)
I phoned ARGOS spares and got them to email me a copy of the instructions.. if you want me to forward a copy of the PDF to you let me know at darkmyble2006@hotmail.com.
Sep 01, 2010 | Audio Players & Recorders
Cant set the time on this one at all
Setting the clock - must be done in standby mode.
Press PROG/CLOCK ADJ button . Either 12H or 24H will display.
Choose your preference by pressing the >>| button, then press PROG/CLOCK ADJ button
Press>>| button for HOUR setting, then press PROG/CLOCK ADJ button to store
Press >>| button for MINUTES setting, then press PROG/CLOCL ADJ button to store.
Oct 02, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
How do I clear the presets on my Aiwa cx-naj20
Hold down the CD Stop button (the one with the black square) under the display while pressing the power button to the left of the display
Sep 25, 2009 | Aiwa NSX-AJ20 CD Shelf System
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Dim display
Replace the display tube...accordianman
Feb 27, 2008 | Aiwa AV-DV75
Aiwa AM-F80 Personal MiniDisc Player Logo
175 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
