Question about RCA HD52W56 52" Rear Projection HDTV
My tv picture and color just went out
My tv picture and color just went all sorts of wrong. it still has picture but is mostly red and green and it is all distorted and twisted what could be the problem?
  • RCA Master
  • 3,459 Answers
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Posted on May 11, 2010
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | Televison & Video
I have a ws-a65 tried to install 1080 hd quality through At&t u-verse missing green and red color only shows yellows and blues help!!!
im just going to assume you have it hooked up wrong, call a TV person and they can come look at it, its really hard to do this kind of thing over the internet
Oct 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Everything in picture on television are green
The basic colors in the TV is RGB & each color has a diff amplitude & frequenc. It seems that the IC controlling the RED & BLUE has lost some of it's capabilities due to lower voltage supplied/regulated by the chip, which generally happens after quite long period of usage. However this seems an inherent fault with visio & most of the early sets do not have this problem sorted out at the manufacturing level & is a problem for most of TV's which are unpredictable & could occur in a month or year. If still under warranty, pressurize your dealer/distributor/service center to sort it pronto or ........... face the consequence..........sodeep
Sep 23, 2007 | Televison & Video
RCA HD52W56 52" Rear Projection HDTV Logo
85 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
