Question about Microwave Ovens
PANASONIC MICROWAVE NN-S960BC/WC seems to be dead. Nothing shows in display, and nothing functions otherwise. Power is OK. Plugging into a different circuit gives same result. Is there an internal fuse?
I had same problen, i changed the fuse inside the microwave, works good now
Posted on Mar 28, 2008
SOURCE:
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Panasonic NN-CD997S microwave
i have microwave problems power trip when switch on the unit. please help me.
Jan 06, 2010 | Panasonic Microwave Ovens
Completely dead; has good power source and fuse ok
Where the door closes there is a a switch you have to take off the cover (plug out device) one of these switchs are probably burnt out
Sep 23, 2009 | Panasonic NN-S541 Microwave Oven
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic microwave oven NN-S960BC/WC begins to operate then stops after about 30 seconds, no warmth, control panel stays on but program ends.
Is it by chance running only 22 seconds before it shuts down?
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | Panasonic Microwave Ovens
Panasonic NN-T793 not turning on and nothing is displayed
Hi, if it went dead while it was in use, then it sounds like the HV section (magnetron, HV diode, inverter section - if used, etc) has failed, possibly only economic to fix if it is a convection microwave.
Jun 14, 2008 | Panasonic NN-S753 Microwave Oven
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Microwave Ovens Logo
374 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
