Question about Poulan "Poulan" Push Mower
Won't stay running
My Poulan 21 inch push lawn mower, less than 2 years old and not many hours, has run fine until today. Today started for about 1 second, and then stopped. Did repeatedly. Has new gas. Air filter seems clean. But, was out of oil. So I added oil. Now, does not even start for a second, either choked or unchoked. Ideas?
  • 198 Answers
You may need to disassamble the carb and clean it thoroughly.
Posted on May 10, 2010
Cub cadet hydrostatic
brake lever on trans could be stuck on lay down and push lever to free up
Jun 04, 2013 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I purchased a 550 series mower last year. It worked great. I used it a week ago and it worked great. Took it out today and it starts right up but won't run for morethan 5 seconds....starts right up...
Hi, remove the bowl off the bottom of the carby and clean it out. My best guess at this stage is that you have water in the bowl. Hope this helps, regards Phil.
May 25, 2011 | Poulan Push Mower
I have had my Poulan Lawn Mower for 4 years. The model number is 961320020. As I was mowing the lawn today, I thought that it might be running a bit sluggish and it dawned on me that I had not ever added...
Four years without adding or changing the oil?!
I think that was the problem right there.
Mowers need oil changes to protect the cylinder walls and valve guides every 25 hours of operation. Thats usually about one season if your yard is under an 1/3 of an acre.
Your mower ran on almost no oil for the last two years. The normal lawn mower only holds 20 ounces of oil. You topped off with 16 ounces! The four ounces still in the motor were probably so full of dirt and metal particles that it was grease! Which is no help to an engine that gets its lubrication by splash oiling.
Your mower should be oiled with 30 weight non detergent oil. Multi Vis oils are for engines with tighter machined tolerances. Your oil choice is going to go right past the piston rings and valve guides creating gobs of smoke! Go get some 30W ND oil at your parts store and put it in....but run the mower first so you can clean out all the gunk in the oil sump. Run it long enough for the oil to flow easily.
Once you put in the right oil you can run it and try to clear out the remaining multi vis oil.
If it keeps smoking...I would say you have permanent damage to the cylinder wall or valve guides.
Good luck and be careful!
Jun 24, 2010 | Poulan Pro " Pro" Self Propelled Mower
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Was running stopped it for 1/2 hour, and would not re-start
IT LOOKS LIKE YOU COIL MAY HAVE CRAPPED OUT ON YOU. THEY NORMALLY WILL QUIT WITHOUT WARNING
Mar 28, 2010 | Garden
Poulan "Poulan" Push Mower Logo
487 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
