Question about Refrigerators
No ice from the ice maker
We have water on the door, but no ice from the ice maker? How do I fix this problem?
  • lboyer840 May 09, 2010
    Great suggestion however, our ref. is a side-by-side. Where do I find the coil for this type of appliance?
  • lboyer840 May 12, 2010
    Some more questions:
    I tried your suggestion and made a jumper between the contact points L & V. I didn't get any water. I then verified the water valve works by applying power directly to the valve, it does. How do I test the ice level infrared sensor? Doesn't this sense the ice level in the bucket? If the ice is low this will create the demand to make more ice? Correct??
  • Refrigerators Master
  • 8,220 Answers
The same water valve has 2 functions. It has 2 coils. I imagine the coil on the ice maker side is gone. Make a romex horseshoe jumper and jump between V and L to see if water comes to the ice maker. That way you would know if that solenoid is working.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 09, 2010
  • Dan Webster
    Dan Webster May 09, 2010
    Check it out
  • Dan Webster
    All you have to do is follow the water line to the rear of the ice box and you will find the watervalve sir
SOURCE: Ice maker not working
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
SOURCE: Ice maker
I am having the same problem with mine.
Posted on Jul 15, 2008
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
Ice maker in Kitchenaid KSCS25FT does not refill. Makes ice cubes when filled manually. How to fix?
When an ice maker produces ice after filling with tap water and then cycles and does not refill with water that is an indication that the=> 2319734 Dual Water Inlet Valve
is defective. Replacing the water valve should get you back into the ice making business. The 2319734 Dual Water Inlet Valve has two sides. One side is for the dispenser and the other side is for the ice maker. When one side goes bad you end up having to change the complete dual valve set. Here is a link to a Whirlpool Ice Maker Trouble Shooting Manual Here is a link to another source for the 2319734 Water Control ValveI will be here should you have questions please ask, Thanks Sea Breeze
Apr 09, 2013 | Refrigerators
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
Ice maker has stopped working. Put in new filter but still no ice. Water dispenser is fine but water will not go into ice maker to make ice. Please advise.
The ice maker has its own valve which is the same part as the water in the door with its own valve as well , replace the dual valve for the fix. It is located where the water line connects.
Phil
Apr 11, 2009 | Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
