Question about Kenmore 75085 Air Conditioner
I am trying to install a new power cord on a model 580.72077 kenmore air conditioner. How do I get to where it connects to the unit.
  • Anonymous Mar 22, 2014
    how do i install a kenmore air conditioner model no: 580.76081500
    Problem Solver:
  • 9 Answers
I had to replace the power cord on mine. Hope this helps
I am trying to install a new power cord on a model - 8_19_2015_5_00_05_pm.jpg
Posted on Aug 19, 2015
  • Kenmore Master
  • 4,654 Answers
This really would be simple after you do this one time. The model number you listed has 3 more digits or numbers on the end=> 58072077200 so if incorrect let me know.The 580 means it was originally built by Goldstar (LG Electronics) So unplug the air conditioner and remove the front cover. There will be a cover plate behind the control knobs and you will need to pull them off. Then the cover plate that hides the galvanized cover behind it. You may be near the capacitor and I always discharge any stored energy with a screwdriver before touching any electrical parts. Touch it across all terminals of the capacitor. A somewhat helpful illistration so let me know when ready, Most of this I will need to explain as we go. Once under the cover read the data plate for voltage and BTU's
Thanks Sea Breeze
Posted on May 09, 2010
Does the Kenmore model 75180 run on 220 volt or 110 ??
Chuck, your particular model (which has been discontinued) had two different models with 115 volt (110 is no longer around) and 250 volt.The rating should be on the manufacturer's serial data plate. Also, you may be able to tell by the power cord that was furnished with the unit.
I have included a link to you Owners/Installation Manual, which will provide more information on how to determine what voltage rating your specific unit has.
http://www.managemylife.com/mmh/owner_manuals/23524/KENMORE-Air-Conditioner-Room-%2842%29-LR707330?brand_name_search=58075180700+KENMORE
Hope this helped you. Please let me know. Thanks.
May 18, 2011 | Kenmore 75180 Wall/Window Air Conditioner
Ve a kenmore ac heat combo model # 58075184500 that the cord was pulled away from the outlet and melted both just slightly. I replaced the wall outlet but the unit seems to have low voltage to it. the fan...
Before doing anything elese I would replace that cord also... it may have damaged to cord too...
Make sure to get a heavy enough replacement cord so it does not burn up again...
heatman101
Dec 13, 2010 | Kenmore Room Air Conditioner
I have a Sharp portable room air conditioner model CV-P10NC. The power plug RESET button and TEST button will not click in order to check out the power plug as the unit will not turn on. They did test O.K....
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Sep 12, 2009 | Heating & Cooling
MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Jul 28, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Power Cord assembly in Sears Kenmore air condtioner
there should be a diagram on the side of the case that will help clarify
Jul 06, 2009 | Kenmore 75085 Air Conditioner
Need power cord for window Whirlpool a/c
Their information is absolutely not correct. You can purchase replacement power cords for any product.
If you prefer, I can provide you with the correct replacement cords; I simply need the brand and model number of the AC units
May 01, 2009 | Heating & Cooling
Installtion Manual
Do you have power cord installed on the unit? If so then you will have to have a receptical near the unit. You set the unit in a window following the instructions set forth in the manual, then you find a electrical receptical near the unit and plug it in. Follow the instructions in the manual for desired temps and fan speeds. There isn't any other necessary connections as the unit is one piece based on the model number the thread was posted under.
Mar 21, 2009 | LG LB1200ER Air Conditioner
Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Oct 08, 2007 | Kenmore 75180 Wall/Window Air Conditioner
Kenmore 75085 Air Conditioner Logo
279 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
