Question about NetGear FS108 8-Port Ethernet Switch
How to connect netgear fs108 to cable modem - NetGear FS108 8-Port Ethernet Switch
  • leeb08 May 10, 2010
    This is helpful. One more question, the router is needed in addition to the cable modem. Is there a router that will act as cable modem and router with NAT in one device? I wonder if Cisco Linksys may be faster???
    Guru:
  • 825 Answers
Leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
Posted on May 09, 2010
Testimonial: "Excellent! In other words i need to purchase either a cable modem/router/wireless all in one appliance. Any suggestions of which to buy, Cisco may be????"
  • 1 more comment
  • Manikandan Raj May 09, 2010
    buy a router thats enough....
    The router will have a dhcp server built-in to it....
    It will have atleast 4 ethernet ports...you can connect your switch to the ports present in router(if you wish to extend the number of ports)....Now the switch will work as a switch from the router....
    Famous Routers like cisco linksys, Netgear, Belkin are available in market....
    According to my view Belkin is cheapest(some comes with lifetime hardware warranty) comes with minimum 2 years warranty and lifetime free technical support....
    Netgear comes with one year Hardware warranty +techsupport....after that you need to pay for tech support assistance too....
    Linksys no idea....
  • Manikandan Raj May 10, 2010
    yes, there are....
    Belkin is manufacturing All in one...
    it comes with a cable modem+Router+wireless antenna....
    but i recommend you to buy a router..because even if the router didnt work sometimes, you can throw it away and continue work using the available cable modem during emergency....
    Also it will be easy to isolate where the problem is....
    and the average life time of routers would be not more than 5 years(it depends)...
    but modems that came along with ISP will work for many years....
    Connection type will be like this...
    cable modem will be connecting to router....Router will be connecting to Hardwired and wireless computers...
    New Friend:
I have a netgear FS516 and an Arris Media Gateway 5 Series Router. I connected a standard cat 5 cable between one of the ports in the back of the Arris to the Uplink port in the first bank of ports on the Netgear FS516 and everything seems to work fine. But now I need to access the next bank of ports on the Netgear. I duplicated the setup using another ethernet port in the back of the Arris to the Uplink port in the next set of ports on the Netgear - but I get several lights blinking on the Netgear and I lose my internet connection. How do I activate the next set of ports on the Netgear?
Posted on Aug 16, 2015
    Brigadier General:
  • 10,406 Answers
If the switch has an "uplink" port, connect a "straight-through" Ethernet cable from the cable-modem to the "uplink" port.
If the switch does not have an "uplink" port, connect a "cross-over" Ethernet cable from the cable-modem to one of the 8 'LAN' ports.
2 Suggested Answers
  • 35 Answers
SOURCE: blinking light on NetGear FS108
One LED is a Link light that will blink on activity.
The other shows link speed.
These boxes have AutoUplink negotiation so no crossover cables are required.
Test again with a standard straight though ethernet / CAT5 cable.
Posted on Mar 19, 2009
Can i connect a netgear JFS524 directly to acable modem
Yes for sure you can do that.As the connector is RJ45.The only think is that for Thomson you need a cross-wired cable to connect to the netgear JFS524. If netgear do have Uplink port then you can use normal or straight through cable.For more infor Cross-wired cable are use to connect between network devices.
Feb 25, 2015 | NetGear ProSafe JFS524 24Port Ethernet...
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Can any one provide me URL to download the drivers
    Hi.
    This is an Ethernet switch. Ethernet switches do not need drivers, they are not managed by the computer, in fact it is the router managing the network connection. No driver needed, just a little experience configuring LAN.
    Here a guide, as you can read no software is needed or available :
    FS108 Installation Guide - QC-201-10249-01.qxd
    Sep 06, 2010 | NetGear FS108 8-Port Ethernet Switch
    I have netgear wireless N-300 router. Linksys cable modem. Arius phone modem ( comcast trip play). Netgear not reconizing ethernet connection. My connection is yellow ethernet cable to linksys, grey...
    If you mean phone modem on PC then no. Check connection between pc and router by acessing the webinterface (instuctions in linksys user manual).
    If all OK there then contact your ISP.
    Sep 03, 2010 | Computers & Internet
    How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
    Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
    Dec 05, 2009 | NetGear WGR614 Router
    Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
    Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
    A. Click on Start—Programs—Accessories—Command Prompt.
    B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
    Once I have this information, it will be quite easy to configure the router.
    Oct 09, 2009 | NetGear WGR614 Router
    Problem replacing 4 port hub with 8 port switch for home network.
    You can obtain IP details for Preferred DNS server & Alternate DNS server from your internet service provider.
    don't use automatic ip addresses.
    best regards,
    Krishan.
    May 08, 2009 | NetGear FS108 Networking Switch
    Blinking light on NetGear FS108
    Mar 19, 2009 | NetGear FS108 8-Port Ethernet Switch
    NetGear FS108 8-Port Ethernet Switch Logo
    1,688 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
