Question about Dishwashers
Beko DFS 1300 dishwasher doesn't move on through the cycle
I have a Beko DFS 1300 dishwasher. When I set to wash it fills with water and heats.it then 'chugs' and doesn't move through the cycle staying in one place.
  • 9 Answers
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
All kinds of qwerks with newer Kenmore units. When did u buy it?
Posted on Jan 26, 2008
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
SOURCE: beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Posted on Jul 22, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
Cannot programme to anything but a cold wash
The computer switch needs replacing (start control)
Jan 21, 2018 | Beko Dishwashers
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just...
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Aug 02, 2009 | Dishwashers
Beko dwd4310 not running
Hi Kirsty did you solve this? I have the same problem.
Jul 22, 2009 | Dishwashers
Beko washing machine fills with water when not in use!!
hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Wont wash
The water level sensing switch could be stuck or not functioning and therefore not cutting off the water when it reaches the correct level and starting the wash cycle.
Sep 24, 2007 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
121 people viewed this question
Top Dishwashers Experts
