Question about Philips Magnavox DVD/VCR Dual Player
URGENT/HELP I wanted to make a copy from VCR to DVD, how do I do that? I have DVD-R disc. I need by Friday
It will dub for a few min, than a message comes up that says this program is not allowed to record and made the move of a dance on my cam recorder I am at wits end have called magnavox and panasonic no one can tell me what is wrong
Posted on Mar 29, 2008
SOURCE:
I have a Toshiba DVD/VCR combo and I want to know if i can record a VHS onto a blank DVD disc ?
It all depends on the model of DVD/VCR Combo and what VHS you want to copy.
Pre Recorded VHS are copyright protected so the system won't let you copy them.
May 29, 2011 | Toshiba Televison & Video
Wanting to find out what type of recordable DVD to use to record a VCR tape to use using a RCA DRC8295N model
Any types DVD dics that have DVD+R copying writing to the dvd disc to it only one time only or DVD+RW eraseable old materials buy copying some else on it.
Feb 28, 2011 | RCA DRC8295 DVD Recorder/VCR Combo
I need to copya vhs to a dvd. Can you give the steps one by one please?
Can you provide the model of DVD/VCR player? Not all models do this.
For the ones that can, you need to use the Dub feature. Put a blank DVD (or one with sufficient space) in the DVD tray; initialize the disc if you are using a rewritable disc (RW). Then put the VHS tape into the VCR (you may want to break off the write protection tab). Then set the unit to VCR mode and forwared the tape to the desired recording point (copy-protected tapes can't be copied). Then some models have a dub or copy button on the unit and/or on the remote (press it and follow the onscreen prompts to select VCR to DVD, recording quality and press Enter to start). The copying will stop when you press Stop or run out of space on the DVD. On some models, you need to do this with the on-screen menus. For those, the look for a Dub feature (where it is will vary in the menus - usually in the same submenu as timed recording) and then select VCR to DVD and the rest.
I hope this helps.
(I'll be glad to provide more information if you provide a specific model. I've worked with several brands and there are some differences in the setup routine. My current unit is a Zenith with a Copy button on both the front panel and the remote.)
Dec 28, 2010 | Philips Magnavox DVD/VCR Dual Player
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Want to copy vcr to dvd on my magnavox mrv700vr
Here is a link to the manual:
http://www.m4c.magnavox.com/files/m/mrv700vr_17/mrv700vr_17_dfu_aen.pdf
It specifically lists disc types that you cannot use to record - it specifically states that you can't use DVD-R discs for recording on this unit. DVD+R or DVD+RW are the only disc types you can use for recording on this unit.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Copying VHS tape to DVD
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Feb 26, 2009 | Philips Magnavox DVD/VCR Dual Player
I recently got a Philips DVD Recorder/VCR: Model No. DVDR3510V/05; Serial No. 0751 010790. I have recorded a VCR tape and would like to transfer this to a DVD±R disc. Can you tell me how to delete...
After you transfer the data to the DVD, you can use a DVD editing program like the DVD remake found on this link
http://www.afterdawn.com/guides/archive/dvdremake_tutorial.cfm
and you can edit out all of the commercials
let me know if you have further questions with this
Oct 07, 2008 | Philips Televison & Video
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Philips Magnavox DVD/VCR Dual Player Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
