Question about Kenmore 72077 Air Conditioner
Install a new power cord.
I am trying to install a new power cord. How do I get to the connections on the air conditioner?
    New Friend:
    Problem Solver:
  • 9 Answers
Hope this helps
Posted on Aug 19, 2015
  • Kenmore Master
  • 8,220 Answers
To do it right you gotta take the case off OR plan be get sone **** connectors and splice into the old cord.
Posted on May 09, 2010
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
Accidentally cut the power chord. what should I do?
get some tape and splice it back to gether. wire nuts would be best .. just make certain your connections are tight and well taped.
Jul 14, 2011 | Frigidaire FAM157S1A Air Conditioner
I have to install a new cord . i need to know where to hook up the power line inside my unit .thank you
To get the best information (because, I can't see the unit) call Haier Customer Support 1-877-337-3639 and ask for Technical Service.
Jun 29, 2011 | Haier HWR12XC8 Air Conditioner
The trailer did not have a air conditioner in it before the trailer place installed the new dometic air conditioner. The trailer year is a 1976 AMF Skamp. I told the trailer place that I wanted a 15000 btu...
You have too small a cord on it if it's heating up and then popping your breaker. The a/c has am amp rating on it's data tag, read it and then read the amp capacity of your breaker and the cord your using. If the a/c draws more than 80% of the rated amps for the cord and breaker then you need to find another way to power it up with a bigger cord and a bigger outlet. DO NOT just install a bigger breaker, it is sized for the wiring in your home and a bigger amp draw on that wiring could burn your house down.
Jun 17, 2011 | Dometic Rooftop RV Air Conditioner
THE PLUG BROKE
Go to your local hardware or big box store and buy a heavy duty replacement plug. Cut the old one off of the cord and install the new one...
heatman101
Aug 29, 2010 | Sharp AF-S120FX Air Conditioner
I need to replace the power cord on my Whirlpool air conditioner - part # PS318855. The Whirlpool replacement parts website says the part is discontinued. Is there a comparable one I can replace it with?
Hi!!
If you need to replace the cord because the plug is messed up, just get a 20A - 30A UL rated plug at Home Depot or any Hardware store.
If for some reason, you need to replace the whole thing, you can also get the cord with the same UL rating at the Hardware Store, they may have one already made. the only thing you need to do is install a female insulated electrical connection on the two main wires and a round terminal for the green wire and you'll be all set. You can even ask the associate to install the terminals for you.
Good Luck!! Don't forget to rate this post!!
Aug 13, 2010 | Heating & Cooling
I am installing a unit owned by my son in his former home. I am unable to find the cable and plug. The closest I have come is a rubber electric cord (3/8" dia.) at the lower right corner. If this is the...
If it's the cord, It should have a plug on it unless someone cut it off.which some people do to hardwire into an outlet. There should be three wires inside an outer cover of rubber. Black, white ,and green. If so, that should be the power cord. You may have to install a new three pronged plug. Good Luck.
Aug 23, 2009 | Danby DAC9003D Air Conditioner
MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Jul 28, 2009 | Frigidaire FAC107P1A Wall/Window Air...
I have a window air conditioner that will not work. Ihave power from the outlet because I tested it with a tester.what are some possible solutions
  1. Has it ever worked before? It could be a manufacturer's defect.
  2. Make sure the power supply is firmly connected to the air conditioner.
  3. Try using a new power cord (if possible)
These are the first 3 things that I would try. How old is the air conditioner? If you are still under warranty, try calling the manufacturer.
Jul 25, 2008 | Computers & Internet
Kenmore 72077 Air Conditioner Logo
134 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
