Question about Kenwood DVD NAVIGATION SYSTEM Car Video Player
My 2005 Honda Accord Navigation system indicates "Check Disc" I verified the disc is readable. I can not get the Navigation DVD to display anything else except when I first insert the disc it indicates "downloading software". What could the problem be
5 Suggested Answers
  • 12 Answers
SOURCE: Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Posted on Feb 16, 2008
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
  • 13 Answers
SOURCE: Problem with navigation CD....
CLEAN THE DISC GOOD WHAT BRAND AND MDL# HEAD UNIT?
Posted on Aug 05, 2009
toy_ladi
  • 484 Answers
SOURCE: 'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Posted on Jan 04, 2010
Testimonial: "excellent thanks"
Unit door open no dvd disc system is not working
I'm assuming you are referring to the Navigation system disc? If it's missing the navi system will not operate. You'll need to purchase a new one from Honda.
Mar 13, 2014 | 2005 Honda Odyssey Touring
Check disc error on a 2005 honda accord ex
I would call Honda customer service and get a straight answer from them. The number is in the owner's manual or available on line.
Jul 13, 2012 | Cars & Trucks
2005 Mercury Mountaineer with DVD Entertainment System that will not read disk
The data on the DVD map disc ages at a rate of 15-20% per year. As the data ages, the functionality of the navigation system declines. Offering GM customers new navigation DVDs will ensure that the customers have the latest information for their system.
General Motors offered a Navigation Disc Update Program for alot model year vehicles. This program concluded on December 31, 2009. The DVD Navigation Update Program policy has changed and customers are no longer eligible for free annual updates, however, a navigation DVD update disc can be purchased for $199 (USD) + shipping.
If the navigation disc is needed for a warranty situation, the disc can be purchased for $120 (USD). The dealer must provide a VIN and RO# XXXXX qualify for the reduced price. The dealer must call the GM Navigation Disc Center, as this option is not available on the website.
The GM Navigation Disc Center launched on March 15, 2006. There are two ways to obtain an updated disc:
* Via the web through gmnavdisc.com
* GM Navigation Disc Center 1-877-628-3472
Technical Service Bulletins are sometimes generated to address specific navigation radio operational or performance issues. When a navigation radio bulletin is issued, it may contain instructions to utilize an advanced vehicle navigation (AVN) software update with a specific part number. GM dealers must order advanced vehicle navigation (AVN) software update discs as directed in the specific bulletin.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 13, 2012 | Cars & Trucks
Navigation system not working 2005 Honda Pilot
Hi,welcome fix ya. the correct disc for your pilot has a black label and the version should be between 2.11c to 2.60 any other disc will not work in your unit. If there is anything else I can help you with let me know.
Apr 03, 2009 | 2005 Honda Pilot
A8 2004 Navigation system not active
NAV unit uses a DVD disc. If its a copy, it may or may not work. I suggest you remove the NAV disc, unplug the NAV unit from power for 4-5 minutes, reconnect the NAV and try inserting the disc again to see if it reads. If it still does not read, another NAV disc needs to be inserted to verify its not a "bad" NAV DVD disc issue. If it still cannot read the second disc, the NAV unit is bad. The handbook feature needs the disc inserted in the slot 1 of the CD changer unit.
Feb 23, 2009 | 2004 Audi A8
2005 honda pilot with navigation, i purchased this unit from the usa and imported it to canada. navigation system doesn't work, where is the navigation disk slot located and is there a disk for north...
same problem, disc is located under passenger seat, talked to honda canada , alpine and honda usa, they dont make a disc for 05, couldnt get nav in 05 cannadian pilots , they dont even make north america disc just stricly usa maps
Jan 19, 2009 | 2005 Honda Pilot
Car Audio & Video Logo
502 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
