Question about Magellan Maestro 4000 GPS
There is a loose piece inside my Magellan 4000 Navigation system. The little connection piece is loose inside. How do I open the system up?
    President:
  • 1,111 Answers
Hi, see directions below..
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
this should help you....let me know if you need more help or info
Ill assume you have either a 31XX, 4XXX model since those are the ones that are alittle harder to get apart then any other Magellan. Read below what I have replied to others with this question.
You have to be careful taking them apart or youll Break the power port and the head phone port right of the board And it will probably screw the board up. had a few were ppl tried to Take them apart the wrong way and broke the tracers right off the board (now there junk)
Note: always start on the side opposite the power port
Anyway, after the screws are out, use your finger nail if you can,(that's what I use) if not get yourself a very small flat screw Driver (jeweler type) and starting from the side opposite the power port (pictures below) and Head phone port (start on the side the power BUTTON is on, starting at the bottom, Slip it along the seam where the front and back of the case Meet, but don't force it down inside the 2 halfs, you want to just put the blade In far enough so it slides along the seem and that its is separating the 2 just enough to unlock the tabs from Each other see the pics There are 6 taps to break free..2 on the top, 2 on the bottom and 1 on each side....don't worry about the on on the port side. Just tip the back of the case upward and that side will come free on its own. When you put it back together, the port side goes in 1st. Tip the rear of the case up and slide it in under the ports and then lay the back down on to the front half and it will snap together.
bill
Posted on May 10, 2010
Plug for power came unhooked. Loose inside
hi ultrapresser follow the link near the bottom for more help..
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
Bill
Standing Member of G.O.T.
Please Support Our Troops
Mar 17, 2011 | Magellan Maestro 4350 GPS Receiver
The power conection port on my gps is loose inside the unit and does not make a good conection so it won't allow it to charge or operate at all. Is this fixable and can the unit be opened up to acess this...
hi scotty01
Bill
Jan 08, 2011 | Magellan Maestro 5310 Car GPS Receiver
Unless I hold the power cord in a certain position which is not always possible I cannot get anything on the screen. I know there's a loose connection but cannot figure out how to solve the problem.
the following advice pertains to the following magellan gps systems.
Bill
Dec 28, 2010 | Magellan Maestro 4000 GPS
The location where you plug in the charger broke free. It's loose inside the unit. How do I get the back off and how do I make the repair.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
Bill
Sep 11, 2010 | Magellan Maestro 4040 GPS Receiver
My magellan maestro 5310 power port is broke the yellow part is floating around inside, can I open the device and repair it?
take the 4 screws out of the back (they are under the little black rubber plugs), then start on the side opposite the power port, then use your fingernail or something similar to split the case....bill
bill
Jul 07, 2010 | Magellan Maestro 5310 Car GPS Receiver
Port for car charger broken
bill
Jul 05, 2010 | Magellan Maestro 4040 GPS Receiver
My magellan crossover gps keeps shutting off in navigation mode - why?
make sure its charging..plug it in to a known good charger..go to the main menu, then systems options then power the power bar on the bottom should be moving from left to right..if its not, its probably the dc power port
If your GPS is not charging, the following models are known to have faulty power ports.
Magellan Maestro or Roadmate..800 860 2000 2200t 2500 3000 3050
3100 3140 4000 4040 4050 6000t
you can buy a power port HERE
or get it repaired HERE
bill
Oct 01, 2009 | Magellan Crossover GPS
Problems with Magellan Maestro? 4040 GPS power connection
Wow if you opened the unit Magellan can tell. If your unit was under warranty You might have talked them into a repair (if your very very very persistent with you can get thin done , eventually ) but now you talk to them to see what they can do but it may be cheaper to go get another unit
Jan 12, 2009 | Magellan Maestro 4040 GPS Receiver
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4000 GPS Logo
69 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
