Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
Change input timing for monitor when monitor ia
Change input timing for monitor when monitor is not available. Input timing needs to be changed on the computer, however there is no way to do this since the monitor does not accept the current input timing.
    Brigadier General:
  • 10,406 Answers
Restart your computer, and keep pressing F8 until you see the Windows "start-up" menu.
Choose "start in safe mode" (to get 800-by-600 mode, which the monitor should accept).
Change the "input timing". Shutdown & restart.
Posted on May 09, 2010
Change input timing for monitor when i can't do anything
Hi Austin
it sounds as though you have a problem with your graphics card drivers and your tv will not accept the lower resolution. Do you have another screen that you can connect to prove/disprove my theory? If your tv will not accept the lower resolution input then you need another screen to enable you to sort it out. Hope this is helpful.
Feb 19, 2013 | Computers & Internet
I am trying to connect VTM-Lcd143 monitor to my computer and the screen doesn't show anything except the adjustment on the screen ... what can I do to make it work ?
Does the monitor have multiple inputs on the back of the panel? For example, there will be the power input, and at least one other input (Blue 15 pin or White DVI).
This could be a matter of the wrong input selected from your monitor's menu. I have seen this issue personally several times. Please check the settings and change the input.
If this does not work, please update this issue with the requested information. Look forward to hearing back from you.
Feb 26, 2010 | Vitek VTM-LCD143 14 inch LCD Monitor
How to change input timing without a monitor
you will not able to do it without a monitor. you'll need to get another montior in order to change the settings on computer. you need to change the resolution on that computer. sounds like the resolution is either too big or too small that it will not display it.
Oct 17, 2009 | Computers & Internet
It says "input not supported" whenever i change the resolution higher than 1280 1080..i changed my vga card to my onboard one...cause at least here i can see everything clear with the resolution of 1280...
hi there,
looks like windows does not know how to handle the monitor.
You may try to disable the onboard graphic card in the BIOS before
hooking up the monitor to the nvidia card. then try to run windows in safe mode(by pressing F8 when booting up), it'll run windows with the lowest available resolution, which will be supported by the monitor.
Now download appropriate driver for monitor, install and reboot.
That should do the trick
good luck
Sep 29, 2009 | HP w17e Monitor
My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
MONITOR FREEZE
Hi
You need to hold down the monitor menu button and you will get the msg on the monitor tht the OSD menu is unlocked....
It will take about 10-15 seconds....
Feb 25, 2008 | Gateway FPD2275W LCD Monitor
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
2,938 people viewed this question
Alun Cox
