Question about Onkyo TX-SR605 Receiver
Onkyo Remote Controle Codes for XBoX 360
Does anyone know if it is possible to use the Onkyo 605's Remote Control to control an XBOX 360 DVD player ?
Try 32083 or 30522.
Posted on Jan 26, 2009
  • krisfraser19 Jul 10, 2011
    Code 33006 for a Microsoft DVD player works for the Onkyo RC-803m remote that came with my Onkyo tx-nr609
Use this: 32908
Code List p, 17 - DVD HIGH DEFINITION
Posted on Jul 21, 2009
There should be a code on your remote index for DVD Player XBOX
Posted on Mar 30, 2008
SOURCE:
I'm trying to connect my old onkyo tx-sr502 receiver to my panasonic smart tv and my xbox 360 to get surround sound. Any help would be appreciated
Hello, Since the TX-SR502 does not have HDMI inputs you need to connect the HDMI from the XBox 360 to the TV. You can connect an optical cable from the XBox to the receiver if the XBox has an optical output. If not you can connect the optical out from the TV to the receiver. Connect to the optical #2 port on the receiver and press the video 2 button. You should have audio. Thank you, Onkyo USA
Apr 26, 2017 | Onkyo Audio Players & Recorders
Onkyo Codes for Samsung remotes?
Hi, unfortunately this remote does not have the ability to program to your Onkyo receiver. You must use your original Onkyo remote to control the volume of it. If you need a new Onkyo remote you can purchase one from Replacement Remotes. You can also buy a universal remote to program and work for both your units, so you will not have to keep switching back in forth between remotes. If you would like a universal I suggest getting the RFS200, this remote will even work if your receiver is not in direct line of site.
Sep 02, 2012 | Samsung BN59-00852A Remote Control
How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
________________________________________
Download Onkyo TX-SR304 users manual here.
Mar 26, 2010 | Onkyo TX-SR304 Receiver
I need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Jan 23, 2010 | Onkyo TX-SR605 Receiver
Need remote code for AT&T box!
Have you tried this AT&T code 00858. Motorola set-top box codes include 00476, 01376, & 01562.
I hope that helps.
Jan 11, 2010 | Onkyo TX-SR605 Receiver
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Jan 04, 2008 | Onkyo TX-SR605 Receiver
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Oct 24, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
4,078 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
