Question about Craftsman 25cc Gas Line Trimmer
Toro proline model 53030 how do you install line and what size line? also what gas do i use ? thnks
    Sniper:
  • 53 Answers
They are usually .60 or .80. mm line size. You use any gasoline that is FRESH ONLY! I can not over stress how many problems that saves you over time. But for that model (and many like it) you must understand its a 2 cycle engine (or 2 stroke) now this is VERY IMPORTANT. Gasoline alone in any 2 stroke engine will destroy it if used alone, without mixing special "2 cycle or 2 stroke" oil with it. Look at the gas cap, or a sticker or a label on the trimmer and you will see a 2 cycle oil to gasoline ratio indication number. That means what it implies, and yes, you mix the two together. Common mix ratios are typically 30:1 (30 parts gas to 1 part oil) Some vary up to 50:1 some as low as 25:1. If its not on the trimmer try the owners manual ITS THERE! generally that means a 2.5 ounce bottle of 2 cycle oil (Not Car Motor oil! There is a big difference in performance for 2 cycle motors. You need to mix 2 cycle oil types only) poured into a 1 gallon container of gas. Shake it up, fill your trimmer with that. Here look at this link. http://www.youtube.com/watch?v=SuGfDNH6fXk&feature=related (Copy and paste it into your browser'd address bar, then hit enter.) They will show you all you need to know on how to restring the line.
Posted on May 10, 2010
Testimonial: "very helpful it certainly will get me started thank you"
Toro s-620 fuel primer button broke
any primer bulb will work if you install it between gas tank and carb in the fuel line
Jan 06, 2015 | Toro Garden
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Apr 19, 2012 | Toro Garden
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
I cleaned my Toro Proline Carburetor and now I can NOT figure out how to re install the linkage. I need a diagram.
That sucks. I know. I'm guessing you have the standard Tecumseh set up that's on all the Toro's I work on (sideways carb setup). I've learned the hard way to take photos; I'll post the one I took. I apologize for the quality; the next one I do, I'll take a high res one but hope this helps ya out. I mean Toro Push Mowers. James
Aug 21, 2011 | Toro Garden
My toro 51970a trimmer has been leaking gas and flooding for the past few weeks, but I could start it. Today, it is gushing gas from the back when I pull the starter string. How do i fix this?
The carburetor needs to be removed and inspected. The malfunctions possibly indicate the need for a repair kit. I've been unable to locate your exact model, but if it has the 2-Stroke engine (gas/oil mix), then you will at the very least..need a gasket and diaghragm kit installed per inspection. There is the possibility that the carburetor needs a complete rebuild and would require the complete rebuild kit. Remove the gas lines (after draining gas). Remove the carb and inspect the screws and tightness of the screws in the 2 end covers. Are the screws tight? If not tighten them up and reinstall, trying to restart the machine. Post back if needed.
Oct 26, 2010 | Toro& Electric String Trimmer
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Sep 07, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Fuel lines dry and brittle how to replace on craftman 24cc gas powered blower vac
take one of the lines to a hardware store and see if they have the proper size. You should be able to change them easily. Just remember to clamp the ends to prevent gas from leaking out.
Jun 15, 2009 | Toro Blowers Rake and Vac - Electric...
Craftsman 25cc Gas Line Trimmer Logo
418 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
