Question about Garden
I have a troy built 2450 pressure washer. The engine runs fine but I have no pressure out of the hose. Does the pump require that you put oil in it?
  • 623 Answers
Do you live where it is cold in the winter? And did you winterize the pump this past winter if it is cold? They need to be winterized or pump damage can occur.
Posted on May 10, 2010
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Honds 5 horse engine on a troy built power washer, need to add pump oil. how do I do this?
There should be a little wondow on the side of the pump body to show you the oil level and a oil filler cap on the top of the pump body . There should also be a drain on the bottom of the water pump this is not the engine its the water pump . It will take 10 -30 or 30 wieght oil check your manual or local dealer for your specific pump oil requirements . But if you use it often change it don't add and do the engine oil tothis is the biggest killer of pumps and engines and pumps nelgeliting oil changes also eighter drain all water from the pump or winterize in freezeing temputers
Sep 16, 2011 | Honda Garden
My Troy Bilt power washer (using Honda GCV160 engine) has no pressure coming from the pump. I checked the water flow, everything seems fine. I believe the pump needs oil added, however, I can't seem to...
I had a similar problem. Turns out I had left the hose disconnected and some sort of wasp built a paper type nest inside the washer tube that the hose connects to. I had to take the pump off and take apart and then cleaned it out with a screw driver. Not too easy to do but finally got it clean. Same thing happened with the hose.
So, if you haven't used it for awhile, check that there is no blockage in the hose or pump tubes. You might be able to blow it out with an air compressor.
Nov 21, 2010 | Honda Black Max 2600 PSI Pressure Washer
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Garden Logo
599 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
