Have a Panasonic Projection TV PT-47wx51c. It is currently shutting it self off, then the red light in the front blinks and can not be turned back on until it is un-plugged. Just befor it shuts itself off ( approx 5 sec after turned on) It shows me the set-up screen for about 1 sec. Is this a common problem and can it be fixed. Thanks Scott
  • 1 more comment
  • scottyb111 Mar 28, 2008
    It blinks 3 times then long pause and then 3 blinks, pause and so on.
    Thanks
  • scottyb111 Mar 29, 2008
    Excellent advice, this was the exact problem with our set, a 300$ fix but the exact problem. THANKS
  • wolfbbad May 13, 2009
    My panasonic cinemavision hdtv bbe turns on then off. 3 red blinks appear. any suggestions?
  • 8,617 Answers
Can you determine if the led blinks a certain amount of times then a slight pause before blinking again? Let me know as it may be blinking a diagnostic code.
Posted on Mar 28, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Mar 28, 2008
    Your set is shutting down because of a convergence error. Change both convergence ICs and also check the resistors right next to them as 1 or 2 of these often go open when the ICs go out. Let me know if I can assist you further.
  • Sonny Berry
    you need new convergence ICs that what the error code 3 is . Also check the resistors next to the ICs for being open as well, change both ICs
  • Sonny Berry
    Sonny Berry Mar 29, 2008
    youre welcome, glad I could help you with your diagnosis.
SOURCE:
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-51hx41e shuts off by itself
older rear projection and should if shut down either display a solid red or a blinking red power light
Mar 24, 2012 | Panasonic Televison & Video
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Power problem
How many blinks is it doing? It has a built in self diagnosis code that it will blink. Pause a second then blink again. Count the blinks then let me know.
Jan 17, 2008 | Panasonic PT-47WX49 47" Rear Projection...
The PT-53WX52
This looks like a problemcausing the shutdown circuit to trigger. The shutdown circuit prevents the TV from being further damaged by an overcurrent or overvoltage event. The overcurent event is caused by a component being over driven and thus it decreases in resistive value causing an increase in current, The over voltage event is caused by a component increasing in its resistive value either due to an open circuit or decrease in the component's conductive area. In any event the shutdown circuits senses these eventes and shuts the TV down to prevent futher damage.
I would suggest taking the set to your local TV repair shop.
I hope this helps,
Shuttle83
Nov 16, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Ekse
