Question about KitchenAid KERC607 Electric Kitchen Range
Kitchen Aid KESC 307 hbs4 electric range control
The oven is not working, and one of the range's surface cooking areas is also not working. The reparir person indicated that the problem was the range control unit. He suggested it be replaced.
Wher can I find the control unit and what is the cost.
Cesar
I have a Kitchenaid glass top range and one of the elements will not get very hot. It will get hot enought that you can't put your hand on it but it will not glow red like the other 3. Can you help me.
Thanks, David
  • 1 more comment
  • Anonymous Apr 12, 2008
    The dual/single element does not work separately. In addition the whole element assembly goes "high" full blast, regardless the setting', if It's "high"or "low" or any setting in between "Lo and High".
    Also no difference, if it is set on 'Single or Dual".
    The control has been replaced.
    llll
  • Anonymous Feb 23, 2009
    One of my dual circuit elements on mly stove top is broken. How do I fix it?
    Novelist:
  • 184 Answers
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Posted on Apr 04, 2008
Why does my oven cook so unevenly? In the top area, the back cooks way faster than the front. In the bottom, the right cooks way faster than the left.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 08, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Hello... range reaches desired temp, food in oven, Beeps F-1, shuts down oven, food not cooked... huge problem kitchen aid supra electric range
You may need to see the secondary error code (F1-E?). The chart below is for a KitchenAid Range. Most likely is a control board issue. We rebuild control boards if you want to save some money compared to new.
Nov 02, 2010 | KitchenAid Kitchen Ranges
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
I cannot turn top oven off from bake. How do I make it work?
have the same problem with kitchen aid stove. Set the cook duration for one minute - then open and closed door. Oven turned off.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Broiler coil sparked and broke, stopped working; 1 1/2 weeks later bake coil burnt out. I got new coils from the manufacturing, and had someone install. They don't work. The surface cooking area works...
Installer either did not do the job right OR when the coils broke they shorted in a manner that fried the oven control. The installer SHOULD have verified proper operation before they left your premises.
Jul 29, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Jul 14, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
oven not workin very well might be a control issue, but top elements work completly seperate from oven control, and theres 2 electronics there $200 for touchpad galss assy and $375 for electronic timer, and switches for the burner might be 50.id make sure I trusted the repairman's diag before proceding
Feb 23, 2008 | KitchenAid KESC307 Electric Kitchen Range
Surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
May 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KERC607 Electric Kitchen Range Logo
613 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
