Question about Tools & Hardware - Others
John deer bh25 leaf blower won,t stay operational starts fine in choke position but when i strt to go to half choke position it increses idle but a second and it stalls
Its probably a clogged spark arrestor on the muffler. John Deere reccomends cleaning or replacing after 25 to 50 hours.
Posted on May 18, 2010
John Deere bh25 blower won't start has fuel and new plug stop switch is ok
Sounds like a dirty carb. If you can take off the fuel bowl and clean it out real good and blow out the fuel jet and make sure there is no dirt in it. That quite often will get you going. An engine will not run if the jet is plugged.
Sep 02, 2015 | Garden
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Turn off choke, engine stops
You may need to adjust the carb.
Jan 03, 2013 | Garden
Bh25 le carb schematic
The waxy substance it gelled fuel. You have to totally clean and blow out all passageways. Resist using any hard tools or drill bits, you want to change NOTHING in terms of size..You just want it totally all cleaned.
Replace all soft parts. Verify the passageways are open. I prefer to soak in carb cleaner, it is strong and nasty, but resolves what you describe. Spray stuff seems to work well, but I worry about areas like venturi discharge systems...Soaking does it.
Dec 11, 2012 | John Deere Garden
What is the fuel/oil ratio of a john deere BH25 leaf blower?
The BH25 that I use from my friend runs on STRAIGHT gas, it is 4cycle. Do NOT put a fuel mix into it!! It has separate oil system.
Nov 24, 2012 | John Deere Garden
My John Deere leaf blower (BH25) will not start. I've had it for several years and have had no prior trouble with it. It uses two-cycle fuel. I usually get the stuff you mix with regular gasoline...
Fuel is no good get rid of it start fresh. First you need to take off the the carb and clean it very good put it back together with new fuel and start blowin, the season is upon us. Good Luck....
Aug 27, 2011 | John Deere Garden
I have a John Deere 2E leaf blower. Lately it has been hard to start but runs fine once it is up and running. Would it help to adjust the H or L screws on the carb?
The H (High Speed) and L (low Speed) should not typically need adjustment. What happens is the diaphragms get stiff and do not operate efficiently. If the unit is over 5 years old and/or the fuel is not completely drained with the unit run dry at the end of the fall, then I would suggest replacing the diaphragms within the carburetor. This along with spark plug change, air filter cleaning and a check of the muffler to insure it is not clogged is considered a basic tune-up.
Sep 27, 2010 | John Deere Garden
Manual for john deere leaf blower
you have to order the Manuel from john deer or a john deer dealer
Oct 12, 2009 | John Deere Garden
Tools & Hardware - Others Logo
382 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
