Question about American Standard 2770.018w.020 Cadet Whirlpool White
Not bubbling the unit hums but not bubbles are coming out of the jets.
  • 21 Answers
I am assuming this is a jacuzzi make sure the air ports are not clogged it has to **** air to be able to make bubbles
Posted on May 10, 2010
My oxygenator pump on my boat turns on but it doesn't always shoot bubbles. All of a sudden it starts to shoot bubbles and then it stops. I can't figure out the problem. Can you help?
your stone or jets are plugged. if stone try to clean it. if jets try to run needle in jets. it sounds plugged up. check lines. if that does not work diaphragm had a hole in it or the push rod is bent or connectoe is loose or worn out. check these as long as motor works it is usually one of these. good luck
Mar 19, 2014 | Rule Livewell Oxygenator Kit With RUL-251
Bubbles are not working on the right side of the foot spa
Depends on how the jet is set up. Many use a venturi device that pulls air through it as water runs out the jet. Many times people will stick their fingers in the jets and knock the venturi out of place preventing the air from being drawn out. If unit has an air pump, I would check for blocked lines.
Apr 02, 2013 | Pool & Spa
Fill tub, press button, hear motor but no bubbles,etc coming from jets
Are the jets open? The center of the jets turn to adjust the pressure of the jets. If this is not the problem, there may be a problem with the impeller in the pump assembly. If you here the pump turning and not buzzing, it could be an air bubble in the suction tube. This tube is the one coming from the front of the pump, if the pump is higher than the tube coming from the tub, or if there is a high spot in the tube, an air bubble is a real possibility. If the tube is level with the pump, there should be no problem with air bubbles and the problem lies in the top part of this paragraph.
Mar 10, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
What is coolant bleeding procedure
do it when engine is cold,
  1. Ignation ON,
  2. switch the heater at mix temperature untill you finish the bleeding procedure
  3. loos the bleeder screw located on top of upper radiator hose,
  4. fill coolant and observe the coolant coming out from bleeder screw if no more bubbles coming out from bleeder screw close it. do not close the coolant filler cap.
  5. Start the engine, rev up 2500- 3000 rpm (constant rev) observe the coolant jet from coolant filler nick and mike sure no bubbles flowing from jet. then close tha cap if you see no more bubbles.
  6. thats all
Jan 24, 2010 | 2001 BMW 5 Series
Bubbles coming out of jets
Only one way to get bubbles and that is by introducing air into the stream most likely there is a leak in the plumbing this kind of leak only leaks air when there is suction. if you are losing no water then you have a suction side leak. WHich is strange because the heatr is not on the suction side.
Jan 01, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
American standard jacuzzi tub will not work. motor hums but jets do not come on
is this a new install? if so you may need to adjust the air intake. Or if you have kids they may have messed with the settings. If the air is closed all the way off....no bubbles.
Oct 18, 2009 | American Standard Antiquity 2038.016.020...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
I try to print but the paper comes out blank, I just bought the cartridges today, but I really dont know what happenes.
If you've replaced the cartridges and still the printer comes out with blank paper, then what has happened, depending if it is an inkjet or bubble jet, is that the pump or heating element (in a inkjet it is a pump and in bubble jet the ink is heated up in the tank to produce bubbles of ink that transfer to the paper. When you do get a replacement, hold up a piece of paper printed from a bubble jet printer.
If the printer is not under warranty, then don't bother for the repair.
If it is a laser printer, what may have happened is the wire that charges to the drum in transferring the image to it is not working.
Aug 21, 2009 | Office Equipment & Supplies
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
American Standard 2770.018w.020 Cadet Whirlpool White Logo
117 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
