Question about Acer AL1711 17" LCD Monitor
Monitor wont turn on power button flashes green and yellow
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: www.elektrotanya.com
Posted on May 09, 2010
4 Suggested Answers
SOURCE: Monitor Flashes Colors when system powered down
Looks like the Burn-in mode is turned on. See here:
http://www.dellcommunity.com/supportforums/board/message?board.id=dim_monitor&message.id=70187
Cecil Thomas
Posted on Jan 14, 2008
tantong
  • 138 Answers
SOURCE: Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 09, 2008
  • 555 Answers
SOURCE: flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Posted on Oct 05, 2009
My screen will not come on and it flashes this message once "VGA NO SIGNAL". Then power button turns from green to yellow (standby mode). HELP!
What computer is it?
When you say power button is yellow, do you mean on monitor or on computer?
Can you try a different monitor?
Perhaps try a different video card
Aug 29, 2010 | Computers & Internet
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Dell monitor e17s fbp.. wont turn on
Flashing power LED light means you may have shorted (Emitter to Collector) out transistors (c5707) or bad fuse (fuse has high resistance) PF751. Those are what you need to check. see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://s807.photobucket.com/albums/yy352/budm/Dell%20E15x%2017x%20series%20PWR%20INVERTER%20BD/
Post back what what you find so we can guide you further.
Feb 27, 2010 | Dell E173FP 17" LCD Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
Monitor power light flashes yellow/green
the monitor power light turns green and then switches back to yellow but there is no signal.
Nov 28, 2009 | Acer AL1917W LCD Monitor
Won't turn on
This is a problem with either the power supply or or logic circuit. It could also be caused by a failure in the back light circuits. One of these problems has caused the power supply to go into protection mode and will not turn on due to bad voltages sensed in the feedback circuits. Return to dealer for service. Hope this helps you .
Dec 26, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
238 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
