Question about Garden
Running but starving for fuel engine revs & slows down revs again slows down
    Guru:
  • 440 Answers
Hi
1st Check for good flow at fuel tap ( if a diaphragm type apply suction to vacuum tube)
2nd Check for kinks in fuel pipe
3rd Check air filter
4th See if it runs the same with fuel cap open (blocked cap breather)
5th Drain carb from bottom of bowl & refill with FRESH petrol ( this gets rid of contaminants)
6th Dismantle carb, clean & check the float valve then set to correct height
Presuming you are correct in your fuel starvation diagnosis these 6 steps should put it right!!
Ride Safe
Bike-Doc
Posted on May 09, 2010
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Won't go on take off
run fault codes and look for a accelerator position sensor problem or MAP/MAF sensor fault.
Dec 22, 2013 | 1998 Honda CR-V
I'm having trouble starting the car. When it idols the RPM's pulsates up-and-down and then it stalls. Once under way the car seems to run fine but without any warning it will die as I start to
check air filter, might be plugged, [dirty so engine is starving for air.] check fuel lines & filters, dirt blockage need replaceing, check for fuel leaks in lines etc, uses fuel & then sucks air causing it to stop, listen to see if fuel pump is running properly & not stuttering could be short in it's wiring
Dec 16, 2012 | 1994 Mercedes-Benz E-Class
Nissan Caravan 1995 petrol manual. Engine seems starved of fuel, loses power then seems to go again.
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 14, 2012 | Cars & Trucks
Tach dies and engine stalls sometimes. i can't press the gas pedal too far or the engine revs and the car slows down but doesn't stall.
Sounds as if it is starving for air or fuel. check the air filter and replace fuel filter. if it still does it check the fuel pressure. if it is low replace the fuel pump
Nov 24, 2010 | 2001 Pontiac Grand Prix
Push mower runs, starves, recovers, repeats
Sounds to be the float and needle needs replaced. The float raises the needle to let gas through the carb. If the float isn't working properly the carb starve for gas. If replacing the float, be sure to clean the carb to.
Jun 16, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
2002 Hyundai Elantra 100k miles - 2.0l - running rough
sounds like the throtle position sensor is miss alined or the idle screw is backed off
Dec 16, 2009 | Hyundai Motor 2002 Elantra
Engine starves for fuel after running about 50 miles or so...
Has Neon do same, I ran fuel at low level, on hot day, ran engine until it started to act up & threw a fuel pressure gauge on it. Was at approx 5 psi. Cold next morning, 48-50 psi. Always hot day about 30-40 miles into work in morning, o.k. Sit in hot sun all day & would happen 3-4 times on way home. Sit and let cool, 20 minutes or so & go again for a while. Cool day, no problem. Change pump I would.
Jul 21, 2009 | 2004 Chrysler PT Cruiser
N reg mx3 1.8 v6 - please help!!
ey man, my names dec.
you should probably check to see if the variable inlet tracks are changing. I had the same problem. its easy to check.
Jun 29, 2008 | 1995 Mazda MX-3
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
