Question about Refrigerators
Whirlpool refrigerator (top mount freezer) model ET8FTKXKQ00
My refrigerator and freezer temp dropped overnight. The fan is running. It is auto-defrost. I cleaned the coils which are located on the bottom--they were very dirty. I let it sit for 2 days and turned it back on--it started to cool at first, but then the air that the fan was blowing turned warm within a few minutes and I am hearing a repeated clicking noise. The frig is approx 6 yrs old, so I am wondering whether or not to just replace it or try to correct the problem--any suggestions? Thanks!
    Scholar:
  • 42 Answers
I feel sure you will find the compressor start relay is probably bad unless it is a Frigidaire manufactured refrigerator. If it is a Frigidaire then if may very well be a bad compressor.
I hope I have helped, supertechks
Posted on Mar 28, 2008
My bottom mount french door refrigerator, the upper part does not cold, it's warm
Sorry your having trouble so soon!
First thing you need to check is inside the freezer section.
The freezer fan, the fan is W10128551 and should be running
along with the main compressor. Since the freezer is working,
I would check the food on the top drawer or on the freezer door shelf.
They too might be soft..without the fan.
I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really
a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time..
John Wright
Jul 27, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
Freezer is very cold but main frig is not cold at all, we defrosted cleaned all ice built up under plate in freezer and still warm
did you check freezer fan behind the freezer? If not working check the wiring for it. If broken fan replace it. Find no leak in door gasket. Temp setting must be at least 5 degree.Thanks.
Jan 30, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Icecream not staying froze meat stays frozen though
Meat is always more dense than frozen dairy product. This soft ice cream issue usually occurs when the circulating fan becomes blocked due to overloading.
Unlike a chest type freezer, top mounted freezers use a fan to circulate to the refrigerator. If the return vents to the freezer become blocked by too many small items, or loose plastic bags the compressor may run too long in an attempt to lower the refrigerator temp,
This may cause the compressor to heat up and kick in the overload safety, further dropping the total temperature.
Mar 05, 2010 | General Electric GTR16BBSR Top Freezer...
Refrigerator runs, not cooling
Sounds like you have a defrost problem. the easy way to check this is to turn the unit off for 24 hours doors open.
Then turn back on and if it starts cooling ok it is a defrost issue
Jun 06, 2017 | Kenmore Refrigerators
Refridgerator and Freezer
Compressor may be warm but not running. What part is brand new? Would you like me to assist you? If yes please make sure your model number is correct. I'm waiting for your reply, Sea Breeze
Nov 19, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Whirlpool refrigerator model#WRT-75680. Have
Assuming the freezer is adequately cool, it sounds like the freezer fan is not running. This fan transfers chilled air to the refrigerator section. The fan should be located behind an access plate in the freezer. If it's running, you should be able to hear it. If you can't hear it, remove the access plate and look at it. If it's not turning, you will need to replace the fan motor.
Oct 16, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool bottom freezer 5 years old everything freezes in the fridge
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
