Question about Kenmore 22422 Top Load Washer
How do I remove the tub from a Kenmore washing machine?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=d7a18986fd4da1a4b7b775afacc55df1
You don't have to remove the motor / transmission etc.
NOTE:
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
Posted on May 09, 2010
Is there an easier way to get you washing machine tub out? I have a Kenmore 700 series
Not too difficult. If you don't own a tub nut removal tool, try using a pipe wrench. You may have to file the scratches off unless you can fashion a copper belt around the nut. Watch the You Tube video posted below. Good luck. https://www.youtube.com/watch?v=j8_TzloPCwY The entire removal procedure should take around 20 minutes. And another 15 minutes to reinstall your new tub.
May 14, 2016 | Kenmore Washing Machines
How do I remove the hub below the agitator on a top loading Kenmore 110.42722200?
You must remove the 7/16s bolt from top of agitator then remove agitator then pull tub out and the seal is in the outer tub.
Jul 19, 2015 | Kenmore Washing Machines
Taking washer tub out of sears model
Please check on this link for tips to remove the tub: Removing Drum
Jan 11, 2013 | Washing Machines
How do I remove a tub paddle from the tub of a Kenmore front loading washing machine 417 41042000
There is a single screw holding each vane in place: remove it, then pull the vane towards the front of the tub. 2 of the 3 in my machine were stubborn: I pried the stubborn vanes forward by putting the handle of a hammer behind them, then pulling. There are 6 tabs on the bottom of each vane that slip into slots that are cut into the tub.
Nov 27, 2010 | Kenmore 44102 Front Load Washer
Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Jan 25, 2010 | Kenmore 22422 Top Load Washer
Clothing is stuck in the tub of my kenmore washer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Finishing nails feel thru the holes in the tub basin in my kenmore elite. How do I get them out? I can here the tub rubing againt them.
the inner tub will have to be removed. if the nails aren't removed, they will eventally wear a hole in the outer tub
Aug 24, 2009 | Kenmore Washing Machines
Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
Mar 24, 2009 | Kenmore Washing Machines
Kenmore washing machine washes but does not release the water.
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Mar 22, 2009 | Kenmore 22422 Top Load Washer
How to Remove the bearing outer race from the shell of the washing machine tub
bearing on most can not be removed there molded in the outer tub comes with the rear half of the tub already installed
Feb 26, 2008 | Kenmore 43052 Front Load Washer
Kenmore 22422 Top Load Washer Logo
189 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
