Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Enigne backfires after I turn the mower off
The mower also seems to lose power when cutting through high grass.
Could this be related to the backfiring after I turn the mower off.
    Sniper:
  • 53 Answers
Probably, but need more info. How old is the mower? Was it fixed or tampered with recently? is it a "cared for" mower? (Not left outside in the rain and snow...etc...) Backfires can have a few causes. Too much fuel, way too lean of a fuel mixture, (Not enough or wrong type of oil or mix ratio) Misadjusted mixture screws on carb, idle set too fast/high, generally it is a adjustment issue though. Try a tune up! Ya small engines need them more often than you'd think! And there is one more culprit for the loss of power you mentioned,and it may or may not be causing the backfires but you never know...and that is the mower blade's "sheer pin" or "Breakable keyway key" If (with the mower off) you reach the blade and try to spin it in both directions and it seems to move out of sync with the engine crankshaft (or wiggles a bit too freely) Than you need to replace the split /broken key with a new one. I had a Craftsman do that to me once and all the power returned like magic after replacing it. BE Careful! Its an easy fix if that is it, but you have to give more info.
Posted on May 10, 2010
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
Aug 31, 2014 | Garden
Why does my zero turn mower struggle when trying to cut grass, it seems to be using half power.
If is a twin cylinder engine this could be very well the problem. Without the engine info it is hard what it could be.
Jul 23, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
Riding mower
If the grass is very tall (more than 10") you will have to slow down to less than 1 mph, if you have a mulch kit on this unit, remove it to get the grass out as quickly as possible. Also, sharp blades & a level deck are important.
Sep 23, 2009 | Garden
Why does my electric mower lose power in high grass? After waiting a few seconds &/or tilting it up, the engine revs back up and can continue to cut. It is a older model. Doesn't have a fan attacted to...
The high grass causes more drag than shorter grass. This means more friction. The tilting lessens the drag, so less friction, the speed increases. It ma need a sharpening but it sounds as though it is running correctly. As you say, it is older so you can't expect new performance. Good luck...Lee
Sep 16, 2009 | Black & Decker 19" Electric Lawnhog...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
617 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
