Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
Left my upright freezer open a crack and now the
Left my upright freezer open a crack, something got stuck in the top. And now the top does not freeze only the bottom does.
    President:
  • 949 Answers
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
Posted on May 10, 2010
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright Frigidaire Freezer, Model#: MFU14F3GW9 It's approximately a 7-9 year old upright freezer. I believe the door may have been left cracked for an extended period of time, but I'm not positive....
if the doors shut okay,and there is no frost,and it is maintaining a steady internal temp(-18C to -20C) why worry.......anything else is going to cost money.......
Apr 05, 2010 | Freezers
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Top of freezer will not freeze
YOUR EVAPERATOR FAN IS STUCK OR BURNED OUT,REMOVE BOTTOM PANEL AND SEE IF BLADE IS STUCK,TRY TO RUN START IT WITH YOUR FINGER,IF IT WILL NOT START REPLACE,THANKS-MIKE
May 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
431 people viewed this question
Top AEG Freezers Experts
Gil Shultz
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you an AEG Freezer Expert? Answer questions, earn points and help others
