Question about Classic Electronics CDR201 CD Recorder
Player side does not recognize a disk. Door opens and closes properly but will not play a CD and display says "no disk". The CDR side works perfectly, plays and records, but of course won't record from a CD placed in the player side. Strange thing is that an identical unit I borrowed from a friend does exactly the same thing.
  • 1,472 Answers
Jncecil
If your friends unit is doing the samething then the problem my be with the disk and not the unit its self.
It is possible that there is a different type of laser in the player side that is not in the recorder side.
So my question for you is what kind of disk are you putting in the player side and have you tried a standard pressed CD to see if it works.
Issken
http://www.fixya.com/users/issken
Posted on May 09, 2010
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Philips cdr778 play side door
remove cover and disassemble the tray carefully, and see if it can be put back together/ reset in the tracks. Hope fully nothing is broke and your back and runnin.
Nov 13, 2007 | Philips CDR778 2-Disc CD Recorder
CDR will not open.
sounds like a worn out chip but quite complex machines to work on
May 11, 2010 | Philips CDR778 2-Disc CD Recorder
Cd-r does not work in pioneer cd player
you need to get to cdr disk that are for audio
May 03, 2009 | Car Audio & Video
Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Sep 08, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
Display reads "open"
Hi! on my Rio the contacts that tell it if its open or close are at the hinge side, 2 metal ribbons that come down from the cover side and touch other metal parts below them on the base side. I'm not sure if this is the same on your model but check it, if not, then on yours it might detect open/close on the latch mechanism, so check to see if the latch action is normal, or if it feels ****, sticky etc. either way - locate the open/close sensors, and make sure they look allright, not bent, broken or dirty, and see what you can do about it. have a nice day!
Oct 07, 2005 | Rio Volt SP50 Personal CD Player
Classic Electronics CDR201 CD Recorder Logo
57 people viewed this question
Top Classic Electronics Audio Players & Recorders Experts
jairo sanchez
Jonathon summesfield
jasbo
jasbo
Are you a Classic Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
