Question about HP Photosmart 2575 All-In-One InkJet Printer
Why does some black test come out blurry when the rest is good?
    President:
  • 2,351 Answers
Chances are there's a build up of ink at the ink cartridge. It’s also possible that the ink cartridge is defective. Remove the black cartridge, grab a few cotton swabs. Drip a few drops of water onto the cotton swab and wipe the copper cartridge contacts.
Dampen a lint free cloth and wipe the bottom of the ink cartridge. (This will free up and remove any ink build-up). Re-assemble and print a test page. If this does not help use the printer’s software and run, "Clean the print heads". If using Win XP left click once on the Start button. Slide up to and left click on Printers and Faxes. Within the Printers and Faxes window right click once on the printer with a little black check mark next to it. From the pop-up list, left click once on "Properties".
Than left click once on Printing Preferences. Than, Left click once on Services. Clean the print heads here.
Hope you find this helpful!
Mike
Posted on May 09, 2010
When I take a picture it always comes out blurry. How do I correct this?
Search Results
    The Top 4 Causes of Blurry Photos, And How To Fix Them ...
    www.digital-photo-secrets.com/.../the-top-4-causes-of-blurry-photos-and...
    Out of focus An image that is out of focus will appear blurry. ... The first is to increase the shutter speed as explained above, The second is to hold your camera steady whileyou take the shot. .... It's always very helpful, and I enjoyed the video.
    Why Do My Pictures Come Out So Blurry? « Samsung Galaxy S3
Nov 30, 2015 | Cameras
Projector goes blurry
the lcd panels is easy to be broken (Life time :about 3 years)
the color of the menu on the screen is becoming blurry,
the black words appears reddish. it is not enough black
there is no relationship between the color with the lamp
you need a new whole prism (with 3 LCD panels)
USD700 (including the freight)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Nov 19, 2013 | Christie LX505 OEM Projector Lamp
I have vertical lines on the entire right side of the screen on my Olevia 242-S11. I've replaced the t-conn board three times, the first and third gave me a black screen, the second gave me less...
most of the stuff from jimmy's its second hand ( not good working or working maybe) first and the last i suppose you got a problem with the power supply on the T con on the second i suppose you have a problem with the big chip in the middle the scalier :D
Jun 02, 2011 | Syntax Olevia 527-S11 Television
Status idle + Test page onl shows top (reddish). Rest is blank.
Check that you're not out of "blue" and/or "black" ink.
For example, no "green" on the page means that the printer did not mix "yellow" and "blue".
Also, the "rest" of the test-page should be "black", if any black ink is available.
Jul 03, 2010 | Lexmark X2350 All-In-One InkJet Printer
Pictures still blurry
Instead of green auto mode set to P mode and chagne the flash setting to non auto.If flash is is in auto mode flash will not fire and picture will be blurry.So your flash must fire every time (and it must not be decided by camera's auto flash mode).
I am sure this will solve your settings.
Please rate if satisfied.
Apr 01, 2010 | Sony Cybershot DSC-H3 Digital Camera
Casio Exilim ex-z57 inconsistent blurry pics
Are you pressing the shutter button half-way and giving the camera time to lock in the focus before pressing the rest of the way? If not, the good pictures were just luck. The size of the card has nothing to do with it.
Sep 17, 2009 | Casio Exilim EX-Z57 Digital Camera
Blurry screen on 50in Hitachi LCD
Sounds like you need a bulb replacement, if you watch tv a lot ave life is about 5 years
Sep 14, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Lcd screen is blurry on my sony handycam dcr-hc20
This does not sound like a CCD problem yet, but a LCD problem. This would require you to replace the LCD screen. Sounds like the LCD inverter is shot. That is the power supply that is required to back light your LCD.
Before we blame that, you should make sure that all ribbon cables are secure and tight.
Good luck !
Feb 04, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Every few photos is blurry
Try to push the shutter button half way down first so the camera will auto focus first. You should hear the lens move to focus, then press it the rest of the way down to take the picture. Your pictures should be much better quality if you do it this way.
Aug 23, 2007 | Konica Revio KD-500Z Digital Camera
HP Photosmart 2575 All-In-One InkJet Printer Logo
168 people viewed this question
Seeker5211
Seeker5211
