Computer speakers. My computers speakers whenever I listen to anything cut in and out on any volume level, I thought it was the speakers and bought new ones but the problem persists. What should I try?
  • 149 Answers
Try uninstalling your sound card and installing it again be shure you have instalation cd for your sound card or correct drivers..
Posted on Mar 29, 2008
SOURCE:
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Aug 08, 2011 | Logitech Z623
I listen to my iphone on my Logitech speakers on my desk. When the volume is low, the speakers work great. However, when I turn up the volume, the green light fades, and the speakers are scratchy. Is...
Hi Roxanne
Sounds as though the power-supply might be faulty. As you turn up the volume more power is required from the supply and it's not delivering - hence the light fading.
Jun 16, 2011 | Logitech LS11 2 Speakers
On my Pioneer vsx-55txi, the protection circuit cuts in whenever I raise the volume to a reasonable level. If I sit 10 feet or more, the volume is too low. I don't like my music or movies loud, but this...
The protection circuit is enabling because the output transistors are 1. drawing too much current causing them to heat-up 2. the transistors are going out 3. the threshold level for the quiesce state is set too high and may need to be adjusted internally. Try to cool down the Unit and see if it occurs again.
Nov 28, 2010 | Pioneer VSX-55TXi 6.1 Channels Receiver
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Speaker volume too loud
Have you tryed to turn down the sound volume on the media player its self as well as the the main volume?
Jun 21, 2009 | Dell 5650 Computer Speakers
BOSTON ACOUSTICS BA735 volume is LOWER than MAXIMUM LEVEL
OK, a few things here. First of all, what program are you using to listen to music? Some programs have an automatic volume leveling setting. If you're using Windows Media Player, it has one. Next, you should NEVER set any speaker/volume/amplifier knob to Maximum setting if you want to get any life out of your speakers. Speaker ratings are for consistent volume levels at a "clean" power level. When you turn any music source up past 80% you are pushing more distortion through the speakers that they cannot reproduce without self destructing. The human ear cannot hear this, and the volume gain is minimal. Next we'll talk about that your dealing with a combination of power levels compiling into an amplifier that may be taking in more than it can aptly amplify according to it's power multiplier scheme to increase the volume at the speaker level. If you've got everything maxed out, you're probably just pushing it all WAY too hard. All over exerted energy that is not being used productively will end up in generating heat and distortion. Those are your 2 biggest enemies when it comes to anything audio. Distortion tears voice coils and generates disruptive electrical currents, and heat destroys circuitry and components in amplifiers. The times where they jump up in volume, just look at that as borrowed time until they blow. If you want louder, get a better or more powerfully rated set, and still, NEVER turn it up past 80% if you want it to last.
Jun 09, 2009 | Boston Acoustics BA735 Computer Speakers
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Headphone out jack is really quiet.
If you're trying to plug the speakers into the headphone connector that will happen.
Headphones are having a high impedance and those loudspeakers a low impedance.
That's why your volume is down. It stresses your audio-amplifier and even blow your finals.
Cheers,
Gerard
Jan 30, 2009 | Televison & Video
Speakers fade in and out when listening to music
ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
May 25, 2007 | Dell 5650 Computer Speakers
126 people viewed this question
Ekse
 Grubhead
Grubhead
