Question about Philips 19PFL5522D/05 widescreen HD ready LCD TV
I have a philips lcd tv and i can't get the diagnostice menu off the screen. I can change the and get the audio to the channel, but all that is on the screen is a diagnostics menu
  • walker4601 May 09, 2010
    the diagnostic menu is as follows:
    stage 1: General Diagnostics
    Details tests not run yet
    Stage 2: Two-way Connectivity
    Stage 3: Object carousel tests
    Stage 4: Frequency level tests
    Details test not run yet
    RUN TESTS (this is highllighted)
    no matter what button i hit on the remote, the test won't run or the menu leave the screen. Audio is okay for whatever channel i change to.
  • Philips Master
  • 12,061 Answers
Download.p4c.philips.com/.../19pfl5522d_05/19pfl5522d_05_pss_eng.pdf
http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,fileinfo/id,13443/
http://www.scribd.com/doc/22277758/Toshiba-TV-LCD-Training-32wl36p
http://www.scribd.com/doc/7581822/RCA-Chssis-CTC-175176177186187-TV-Training-Manual
Ok, please find above, service manuals, and top, a user manual. inside there are troubleshooting and repair procedures they should help you isolate your problem and hopefully fix.
usually it is the character generator & MPU that goes faulty, and erroneously displays the data on screen.
Posted on May 10, 2010
  • 666 Answers
Its not a program or software issue if thats what you are thinking the diagnostic menu should be up due to something preventing picture because or shortage or burnage if you can give us any info about the diagnostic menu it would help
Robb
Posted on May 09, 2010
Philips tv digital disappeared
There may be a firmware upgrade needed here--ask Philips what is available for this model.
Jun 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
My Philips LCD TV just changes channels by itself
it could be one of the buttons to change channels is jammed
Jul 13, 2010 | Philips 42PFL7422D 42 in. LCD TV
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
How to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Jun 16, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Pic.not fitting on screen
the black bars on the sides are normal there are settings in the menu to change the screen sizes.
Dec 01, 2008 | Philips Magnavox 42MF521D/37 Television
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
Nov 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Philips 19PFL5522D/05 widescreen HD ready LCD TV Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
