Question about Dell Inspiron B130 Notebook
B130 to TV
Is it possible to connect my B130 to a Tv?
What is needed?
  • 236 Answers
You could try a VGA to RCA/Composite cable, but I doubt that would work.. Unfortunately, you laptop does not have a tv or s-video out, so the only other way to do it is with a TVTuner box, like this one:
http://www.kworldcomputer.com/product/analog/012/TVBOX1440.htm
might be able to find something similar at a local PC/electronics store..
Runs for about $70 CAN
Posted on Mar 28, 2008
  • Dave MacPhee
    Dave MacPhee Mar 28, 2008
    The reason a VGA to RCA cable probably won't work is because a pc and tv have to completely different signals.
    Problem Solver:
  • 16 Answers
Yes it is, as an external monitor. That model laptop has VGA out (15-pin) so the TV you would be connecting to would have to support VGA in. Most of the new LCDs do and even some older tube types, but most do not.
You can still output to your TV if you get a scan converter basically plugs into VGA and outputs to composite or RCA.
They come in different price ranges and features. Here is a good start for you.
http://www.compusa.com/applications/category/category_slc.asp?Nav=|c:1430|
No, I don't work for CompUSA, lol, they just got lucky, Try Newegg or TigerDirect too.
Hope this helps =)
2 Suggested Answers
6ya staff
SOURCE:
Danilo Gonzaga
  • 356 Answers
SOURCE: what do I need to connect my dell Inspiron B130 to
Hi. Try buying a VGA-to-HDMI cable/adapter and connect the VGA to the side of your Dell B130 and the HDMI end to the back of your Viera. Press Fn+F8 on your laptop and you should be able to view the display on your TV.
Hope it helps... ^_^
Posted on Jun 03, 2010
I connected dell ispiron b130 to tv i have sound but no picture
you need to activate the secondary monitor ..To do that go to the display settings ..and you will see 2 monitors numbered 1 and 2...press to identify first ..and it will show you on the screen which monitor it is ..and after that ..select the other in the image by clicking on it ...than select to activate it under...select clone mode if you want to have the same image on both ..or select other option if you want ti as an extension ..
You can activate the secondary vga exit ...from the keyboard...by pressing Fn ..and the key (Fkey ) that shows a monitor on it ..pressing these 2 in sequence will enable the secondary monitor...If non of these will work ..you may consider to reinstall the video driver..In some cases the image on the tv will appear in black and white ..and will only be normal if you install the computer with the tv plugged on ..(I encountered several cases doing that )
Good luck !
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 02, 2011 | Dell Inspiron B130 Notebook
What do I need to connect my dell Inspiron B130 to my panasonic viera tv?
May 19, 2010 | Dell Inspiron B130 Notebook
S video for laptops
Take a look at this web site and see if it's what you're looking for... http://www.golaptopparts.com/DELL_Inspiron_b130-Dell_laptop_external_S_Video_cable_044ctv.html
Jun 04, 2009 | Dell Inspiron B130 Notebook
No images from laptop to pc hook-up
you need to change the tv to pc and you have to go to display properties and under settings click on the little monitor with the 2 on it and check one of the boxes that say use this device as my primary monitor or extend my windows desktop onto this monitor. try that
May 07, 2009 | Dell Inspiron B130 Notebook
Vga
just buy a Monitor like cable buy a generic one or branded u will find it in all big stores in PC section it is a 15 pin Monitor like cable just join both ends and all set , select the input source of LCD TV to PC if it is not auto bye
Feb 19, 2009 | Dell Inspiron B130 Notebook
Setting to connect laptop to tv
You need to change the input on the TV. Sound like you have everything connected correctly.
Please rate. Thanks,
Feb 17, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
1,930 people viewed this question
Ekse
Clive
Clive
Alun Cox
