Question about Dryers
The dryer drum feels loose, with a lot of play when heled through the open door. When in use it sounds as though it is rubbing internally. I have had a look but cant see how the drum is held in place. Unlike the washing machine which is attached to a spindel through bearings. Can this fault be repaired? or is it a bin and buy a new dryer?
  • 269 Answers
I dont know what make or model you have but most dryers run on guide rollers at the front bottom but also have nylon or felt bearers around the front and rear of the drum there is also normally a brass bush at the rear onto the drum shaft.To get the drum out you normally have to remove the rear casing or on some you can take off the side panels for inspection.It can be repaired depending which bit is worn and how much.
Hope this helps.
Posted on May 09, 2010
Testimonial: "Thankyou for that information, I will have another look at this in the morning.Very quick responce thankyou."
The drum on my servis easy logic has become very stiff and the machine makes a lot of noise. What do I do?
Sounds like the drum bearings have gone. If you open the door and put you hand inside the top of the drum and push up, does it move up and down and feel loose. If so it needs new bearings. Unless you feel confident enough to repair it yourself you will need an engineer.
Feb 19, 2015 | Washing Machines
DRYER MODEL DE7400P FRIGIDAIRE IS MAKE NOISE LIKE RUBBING METAL HOW DO I FIX?
Hi martyski39...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your dryer drum is mounted in the rear with a bearing, most likely the bearing is faulty and making the grinding noise, or maybe two conditions exist.
1...Bad drum bearing noisy
2...Bad drum bearing noisy, and with play in the bearing allowing the drum to rub the felt seal away at the door making metal to metal contact.Check your door for obvious rub signs...
I will include a parts house webpage link where you can look at you "exploded" view of your dryer and order parts also.
Please take time to rate me
http://www.partselect.com/MultiModels.aspx?ModelNum=de7400p&searchTerm=&RefineSearch=0
Aug 30, 2011 | Frigidaire Dryers
I have a frigidaire gallery series dryer, model number GLEQ2152ES1. It is approximately 2.5-3 years old. It is a front loader. During the normal cycle (the only one I ever really use), things always get...
Party *****. Sorry, I couldn't resist. It sounds as though your machine has been moved and something has become loose inside or is not properly aligned causing the drum to separate from the seal. If you open the door and feel with your fingers just inside and behind the door area around the complete circumference of the drum you will feel a rubber of fiber gasket or seal. If that seal has become damaged or pulled away from the frame that is what is causing your problem. Does the dryer make any unusual noises that you may have recently noticed? If so it could be that the support bearings that the drum ride on are damaged and may need to be replaced. If that is the case there is no need to buy a new dryer. If you feel confident in doing the repair yourself it's a little complicated but can be done with simple tools. If not then you may want to consult your local yellow pages for a reputable appliance repair person to complete the repair for you. Please be careful as there are a lot of fly by nights out there who will cause you more harm than good.
Aug 19, 2011 | Frigidaire GLEQ2152ES Electric Dryer
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
The dryer is making loud noises. It still dries but sounds terrible.
If the dryer is old, the belt is probably worn and needs replacing, or the felt/teflon pads that allow the drum to turn are worn out and need to be replaced (you will know because the sound is metal rubbing against metal).
If it is fairly new, the mounting bolts on the motor might be loose.
Either way, you need to open up the dryer and look inside.
Aug 19, 2009 | Dryers
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
I keep replacing the dryer belt, due to it keeps getting stretched out, how can i prevent it stretching?
There are only two things that I can think of, both related. 1. The drum is turning with difficulty. 2. The drum is dropped down in the cabinet letting the belt be loose. Open the dryer door and feel around the opening just inside the opening. Feel for the felt seal. Is the gap even top and bottom? My guess it's not. If not, he top part which is the support for the front of the drum is worn out, letting the drum tip down and loosen the belt. Check the rear bearing. With the belt loose, pull up on the back end of the drum. Does it move up and down in the bearing. If it does the rear bearing needs replaced. Both are simple to do.
Jun 06, 2009 | Maytag ADE7005AYW Dryer
Makes loud sound when spinning - seems like off track
The bearing is worn and now the drum support is rubbing against the metal mount. I do not know what type of dryer you have but my web page covers a lot of material. The dryer that is easiest is mentioned here, plus I have pages on your dryer as well.
READ MORE
May 25, 2009 | Dryers
Kenmore 110.84821300
The rythmic rubbing sound you are hearing could be coming from a few sources. It could be drum support rollers that require lubrication, bulkhead screws that have come loose, the drum seal not seated properly, or a silencer plate that has come off the compartment side and is rubbing on the drum.
First, look inside the dryer along the seam where the drum meets the front and rear of the dryer. You should not see any part of the felt drum seal protruding inside the drum. Sometimes the seal starts to come loose or becomes misaligned and sticks through inside the drum. This will cause thumping and excessive noise. If you have anything caught in the drum seal (i.e., a screw, change, etc.) this can also cause excessive noise.
Remove the dryer top panel and start the dryer and watch for anything obvious rubbing on the drum. The top comes off by removing the screws in the rear and sliding the panel back, then up. (CAUTION: DO NOT get your hands around the drum while it is rotating and any of the electrical connections). Look for any vibration from from the rear bulkhead (this is the back wall of the dryer where the drum rides against). Sometimes the screws holding the bulkhead to the cabinet come loose.
Another thing to look for is a metal silencer plate that is usually mounted along the side panels. This plate is glued on and is used for noise reduction. Sometimes it comes off and will rub against the drum.
If everything checks out good, remove the lower panel under the door by removing the screws under the bottom edge (HINT: Placing a small block of wood under the front feet of the dryer can make this easier). The panel will drop down then come off. If it gets stuck, tap on either side to knock it loose. Start the dryer again and look/listen for any noises coming from the drum supports. The drum rides on the drum supports and they require periodic cleaning and lubrication.
The drum light could be a lamp socket problem and/or wiring. Make sure you are using the correct bulb as well. I believe the bulb is only supposed to be a 25W bulb. This isn't related to any long dry time problem.
The heat problem could be directly associated to clogged dryer ducting. If the dryer is full of lint when you open it, you will have to thoroughly clean the vent ducting and interior cabinet. NOTE: This is a fire hazard!
Some things to try: Remove the dryer exhaust hose and start the dryer. The air leaving the back of the dryer should be forceful and hot (about 140 degrees F). If the air flow is weak and cool, you have a clog INSIDE your dryer. If the air flow is normal, check the vent ducting from where it leaves your dryer to where it exits your home. The dryer ducting should be cleaned routinely and kept clear of obstructions.
Your heat problem may not be a component at all. Double check your dryer interior and ducting and let me know what you find. I hope this helps you.
Apr 10, 2008 | Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
