Question about HP Compaq FS7600 17" CRT Monitor
Hp Compaq Fs7600
When I go to click on You Tube videos they only play for about two seconds and video freezes up and and few seconds of sound.
  • Anonymous Feb 14, 2009
    last night i was on you tube watching my favorite videos and there did not seem to be a problem with the video play back at all. the next day i loded onto you tube to watch some videos and it would begin and a few seconds later, freeze compleatly and some quick frames would play and then freeze again.
Can not burn a cd. it says to connect to a burner.
Posted on Nov 09, 2008
  • 286 Answers
This is not a problem with your monitor.
This is a problem with your computer, or your internet connection.
Having said that, there are a ton of things that could cause your computer to act up, freeze and sputter.
I would say, backup your important files and reinstall the restore disc that should have come with your system. Either that, or find someone you know who's good at operating systems and software, and get them to correct your problem. I just don't have the patience for software problems.
Posted on Mar 28, 2008
SOURCE:
On my Samsung Galaxy note 3 suddenly when I play a you tube video after a minute the picture freezes but the sound continues to play! Any suggestions how to fix this please?
Having same issue on my Note 3 recently on every video on YouTube. Video stop playing every 20-30 seconds but audio keep going. I have to touch position slider every time to make video playing again. Happens multiple time for each video. My friend suggested me to go for Mobile phone repairs
Samsung Galaxy Note 3
Nov 19, 2014 | Cell Phones
My compaq fs7600 monitor wont turn on
Hook a spare monitor to the computer, if no change! the Video Graphics Card is suspect usually built into the motherboard. But if spare shows picture, the problem lies in the HP monitor, as a last resort change the video cord from the computer to the monitor "if possible" to rule out something simple.
Mar 15, 2012 | HP Compaq FS7600 17" CRT Monitor
When i play a video or audio file it hangs and freezes its sound?
hi check in mother board may be some capester bulb if show u change it
click yes for vote
Feb 22, 2011 | HP Compaq dc7600 Small Form Factor PC...
Monitor not working, hp pavilion f1703
Hi, it sounds like one or more pins on the video cable connector are bent. You can detach the video cable from the PC and check the pins, they should be straight, you might find that one is bent and shorting with the earth. I hope this helps.
Jul 22, 2010 | HP Compaq FS7600 17" CRT Monitor
My compaq monitor fs7600 has flashing thin lines running up the screen then the lines bunch up together and the rest of the screen in left black help please
Hi Rubee,
Please get into BIOS mode and check whether there is a flashing lines. If Yes, change your video card or contact your Hp technician.
Jun 14, 2010 | HP Compaq FS7600 17" CRT Monitor
Stuttering videos on you tube
It's because the video isn't downloading fast enough. When a video starts playing just hit the pause button ( || ) and do something else for 2 or 3 minutes or so. When you come back, you will see that the red line has advanced most if not all the way to the right. Then hit the play button ( > ) and your video will play without stuttering or freezing.
May 13, 2010 | Computers & Internet
I recently switched back to my FS7600 monitor and since then, i've had an on-going glitch. Every few seconds it just freezes for a very brief moment. its also screwing with the sound when it glitches. what...
A good place to start would be to go to start - control panel - system -hardware - device manager. Click display adapters and see if the PC first recognizes what you have installed and two, see if any other components are having troubles being identified.
Apr 15, 2010 | HP Compaq Presario SR1950NX PC Desktop
Video freezes for few seconds plays for about ten seconds then freezes again.
Is it only you tube? try www.2wire.com run the speed meter. See if it mabey is your internet connection speed
Nov 09, 2009 | YouTube Videos
Monitor resolution is poor
check your video display drivers. this will cause issues with video display on monitors, look on your computer manufacturers site for the most up to date ones. then right click select properties while in the desktop, go to graphics options or graphics and check your resolution to make sure you have the highest possible settings for that monitor....
Good Luck!
Ruben
Jul 19, 2009 | HP Compaq FS7600 17" CRT Monitor
Blank screen, clicking sound
It happened that to me last year. After 2 weeks of cracking sound symptoms, my monitor begun to blackout - no video signal but the indicator light is still available. I checked it inside using my tester, one of its transistor was burned-out. I tried to replace it and its working up to now. Possible cause of this is probably overuse of monitor without proper ventilation & cooling causing electronic components to overheat. Since I will not be able to actually check your monitor, the best solution for this is bring your monitor to a qualified TV/CRT technician in your area for proper diagnosis. He's the right expert and the second opinion to that kind of problem.
Dec 02, 2006 | HP Compaq FS7600 17" CRT Monitor
HP Compaq FS7600 17" CRT Monitor Logo
82 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
