Question about Kenmore 24032\24036 Top Load Washer
When it goes to rinse cycle it just clicks and nothing else happens cant even move it to spin cycle, same thing happens
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on May 09, 2010
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Why won't my whirlpool model #LSR8233JQ0 go through the rinse cycle or the spin cycle
i have no info on this model, but if its a front loader then you will be looking at your drain pump motor as at the start of the rinse and spin cycles it will need to drain if it cannot it will not even attempt to continue on, so take that little drain pump cover off and have a look inside the propeller it may just be jammed up, if not it may be blocked somewhere along the hose or just a faulty pump altogether, if its a top loader you will be looking for the same thing but if it isn't the pump it will be the lid switch that senses the lid has been shut as all whirlpool top loaders must be able to activate the lid switch or else it cant spin (simply a safety feature to prevent injury), get back to me if you have any questions
Nov 21, 2011 | Whirlpool Washing Machines
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
Washer, goes into wash cycle o. k.when it goes to spin it does nothing. you can move the timer on to rinse and the agitator will move. it will not go into the spin cycle any where
Return it, I had the same thing. It was a problem they made putting it together. The misconfigured the buttons when rewiring them. :)
Aug 05, 2009 | Whirlpool Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Will not spin
You have either a bad lid switch, a bad drive coupling or a bad timer. If you can move the timer dial to spin manually and turn it on and it spins the lid switch is good and the timer is bad. If you manually move it to spin and the motor runs with no spin, the drive coupling is bad. If you manually move it to spin and nothing happens, the lid switch is bad.
Jun 11, 2009 | Kenmore Washing Machines
Top-loading, direct drive Kenmore model won't do spin cycle
In other words it pumps out but when it goes into spin nothing happens. The first thing to check is to remove the tranny(get the agitator out) take the 3 bolts loose and slide out the tranny(no need to get the tub out) Take a look see at the plastic brake release collar mounted on the bottom of the basket drive. The ear will break off and thus no spin.3ef16e8.jpg If that looks ok let me know...
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
