Question about Canon iRC3100 Printer
Canon iR 3100 CN Fehlercode 000602-0202
  • 1,219 Answers
Hdd error - call service!!!!
But if you want do something on your own:
A:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HDCHECK*.
3) When done, turn off and then on the main power.
B:
1) Find the appropriate CHK-TYPE from the table 'HDD Format' ; then, make the followingselections, and type: COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CLEAR.
C:
1)** Start up the machine in normal mode (i.e., turn on the main power while pressing the 1 and 7 keys ; then, make the following selections, and press the OK key:
COPIER>FUNCTION>SYSTEM>DOWNLOAD).
2) Perform formatting of DOSDEV4 using the Service Support Tool.
D:
1) Replace the main controller (main) board.
2) Remove the image memory (SDRAM) and the boot ROM from the previous board, and attach them on the new board.
E:
1)** Start up the machine in safe mode (i.e., turn on the power while pressing the 2 and 8 keys).
2) Format the HDD (ALL) using the Service Support Tool, and download the system software (SYSTEM, LANG, RUI).
F:
1)** Replace the HDD, and start up the machine in safe mode (i.e., turn on the main power while pressing the 2 and 8 keys).
G:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
H:
1) Turn off the main power; then, turn on the main power while pressing the 1 and 9 keys (so that the machine will automatically start its remedial program*, turning
the control panel solid black).
2) When done (i.e., when the control panel turns white), turn off and then on the main power.
If the machine does not run its remedial program in response to the foregoing step, go to E.
I:
1) Find the appropriate CHK-TYPE in the table "HDD Format"; then, make the following selections and enter CHK-TYPE.
2) Make the selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK*.
J:
1) Make the following selections, and enter '4': OPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK (1 to 5 min).
* Takes about 30 to 50 min.
** As necessary, ask the user to use the RUI to collect address book data, transfer settings, and user mode settings.
Posted on Jun 16, 2010
My canon IR 3100 CN displays an error code E000004-0001 plaese help me solve
E004
The main thermistor (TH1) has an open circuit or has poor contact. The sub thermistor (TH2) has an open circuit or
has poor contact. The thermal switch (TGP1) has an open circuit. The main heater (H1)/sub heater (H2) has an open
circuit. The AC driver PCB is faulty. The DC controller PCB is faulty.
E004 0001 protection circuit error of the fixing unit
Description: A short-circuit is detected in the triac (for 1 sec or more continuously) while the heater remains off (hardware detection) for 40 msec continuously.
Remedy: Turn off and then on the main power supply.
Remarks: fixing assembly triac malfunction/13V power supply error
Feb 04, 2011 | Canon imageRUNNER C3200 Color Printer
Canon ir 3100 cn E805 003
E805 fan error
Description
With the ITB fan in operation, the machine does not detect a lock state for 5 sec continuously.
Remedy
Turn off the main power, and check the DC controller PCB; then, turn the power back on.
Remarks
Disconnected fan connector; absence of lock signal because of fault in fan.
Nov 09, 2010 | Canon Office Equipment & Supplies
Canon IR 3100 CN needs pasword
you need to clear thepassword in this order touch ADD FUNC key then the 2 and 8 keys together then touch ADD FUNC key again lcd screen should change touch copier then function then clear then pwd then ok then yellow reset 3 times that should do it
Aug 24, 2009 | Canon imageRUNNER C3200 Copier
Cannon IR 3100 CN Itermediate Transfer Belt error code E00070-000
The E00070-000 is not a ITB problem, but a full wastetoner. Open the front cover find the white bottle in the middle, remove the black screw, remove the cover over the top of the bottle and empty the bottle. Be sure to clean the top of the bottle so the sensor can see that the bottle is empty. Restart the copier.
Jun 04, 2009 | Canon iRC3100 Printer
I have a problem with the printer in ir 3100 cn
Change the printer properties setting on the computer from Normal or Draft where it is not to Best. That'll fix you up.
May 25, 2009 | Canon iRC3100 Printer
I have toner of Ir 3100 but I want to use in ir c 3200 is it
Well toner compositions change to work correctly with different developers. If you use the wrong toner/developer in your machine you WILL need a tech to de-contaminate your machine at a hefty price. That is why the manufacturer makes the bottles different, so the customer cannot use the wrong toner in the machine. DO WHAT YOU WILL.. But I advise Strongly against it.
Apr 03, 2009 | Canon imageRUNNER C3200 Copier
Canon IR3100 CN making grinding noise
hi..there...you may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
Feb 03, 2009 | Canon imageRUNNER C3200 Color Printer
Canon copier ir 3100 cn error code E000602 - 0202
the hard drive containing the software that drives the machine has an error. Corrective steps would be to contact to a Canon technician, who can first try to re-install the software, and if this doesn't work the hard drive has probably crashed, meaning that the drive will need to be replaced and the software re-installed
Jan 23, 2009 | Office Equipment & Supplies
Network Scaning on a Canon IR 3100
color scangear needs to be loaded and setup
Sep 05, 2008 | Canon imageRunner C3100 Copier
Canon ir 3100 cn error code e000020-0081
HP Photosmart C 310series-driver Vindows Vista
Aug 09, 2008 | Canon imageRUNNER C3200 Copier
Canon iRC3100 Printer Logo
408 people viewed this question
old marine
old marine
