Question about Princeton Digital LCD17 17" Flat Panel LCD Monitor
HL710S Daewoo Monitor
Okay we need help here. We bought this computer used and we know the monitor worked when we were looking at it. Brought it home and nothing, no picture, no green light to show the monitor is on. Connection are correct and tighten. Any suggestions? Pls help
Jenny and Ralf
  • lucian782 May 09, 2009
    I tried everything possible with my Daewoo 17 TFT LCD Monitor Model HL710S without results.I have 1 second signal then No Signal at all
    New Friend:
I HAVE A 17 INCH MONITOR AND IT WONT POWER ON MY POWER WENT OUT AND NOW IT WONT POWER ON AFTER POWER WENT BACK ON
Posted on Sep 02, 2010
SOURCE:
BSOD on new computer
BSOD is not a good term to use. That term means that screen comes up WITH WHITE writing on it and it shows what the error was that caused the problem.. So if it is a true BSOD then what are the codes that show up?
Mar 19, 2018 | Dell Computers & Internet
Vertical n horizontal ic
Are you asking about this LCD Daewoo (F227B) monitor? LCD monitors do not use Vertical/Horizontal IC like the CRT type for the H/V Yoke.
What is the problem with the monitor?
Common problem with LCD monitor:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | Daewoo F227B Monitor
Daewoo w9zq 19"tft power light flashes but no screen :s
Open it up and check for bad caps in the power supply first, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 12, 2010 | Daewoo F227B Monitor
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
X2gen MW19R user manual
Maybe they put more volts on it, because of the cable length. About putting the manual on Fixya. I do not know how you would do that. I know that you can have a little more volts and be okay but not enough is bad. Are you sure it is the correct cord?
May 22, 2008 | Computers & Internet
Daewoo computer monitor
You need to get your computer in the correct resolution and refresh rate to make the monitor work. It looks like the correct numbers for your monitor are:
Resolution: 1024x768 pixels
Refresh Rate: 60 hz
You can change these settings in the display tab or display properties (In XP - right click desktop, click properties, under settings tab adjust resolution and then click advanced, the monitor tab, and make sure refresh rate is set to 60 hz)
Mar 29, 2008 | Gateway FPD2275W LCD Monitor
Computer not recognizing moniter
Resolution set too high for display.
Attach TUBE monitor, Start Windows, change resolution to 1024x768 (MAX) and then hit APPLY/OK.
Also check refresh rate, it is listed in hertz (hz) in advanced settings. Should be 70-72khz not faster than either.
Shut down PC, Connect LCD, you should have a decent picture.
Dec 13, 2007 | Microtek C593 15" Flat Panel LCD Monitor
No power in my Daewoo Monitor
Hi, Youo have zeroed in on the problem area. It looks like a power supply problem. More often than not, there is a fuse inside. If you would venture to open the unit up, do a visual check on the fuse. If it is busted: 1. Clean - no burnt/scorching/black marks inside the glass tube, then you can simply replace and hopefully the unit will be operational; 2. Dark smudges - or small burnt metal pellets inside the glass tube, then it is possible that you have other defective components that caused the fuse to blow. Normal components that are known to go bad are the big capacitor and or the power transistor regulator. Most current designs uses a switch mode power supply where your mains AC voltage is converted to DC that powers a circuit that eventually produces a lower DC voltage say 12VDC for use of the monitor. Should you venture a DIY (do-it-yourself), pls remember safety precautions when working with powered electronics. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Daewoo F227B Monitor
Open Questions:
change password aol email @{18OO~8O31O69} phone number There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 21, 2019 | AOL Computers & Internet
See all Princeton Digital LCD17 17" Flat Panel LCD Monitor Questions
Princeton Digital LCD17 17" Flat Panel LCD Monitor Logo
326 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Sr. Pelo
Sr. Pelo
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
