Question about SanDisk Sansa Clip MP3 Player
It seems to be on pause and I can't get it off of
Its like permanently on pause. I can't seem to get it off of pause.
  • downtowngina May 10, 2010
    Where is the reset button? I think this is an older model (maybe 2yrs). Very basic.
  • downtowngina May 11, 2010
    after reading other comments, the only reset button I see is the on/off switch. When I try holding it in the up position for 20 secs, I just turns off.
Try holding the reset button
Posted on May 10, 2010
My Frigidaire dishwasher Model 2409 pauses about 8 times before it goes into the next cycle and seems to be spurting water then pausing, then squirting & pausing like 5 to 8 times ?
Good Morning Tim Taylor, thanks for your inquiry!
Based off the information you have provided I see your Frigidaire dishwasher is pausing multiple times before cycling. From what you have described it sounds like the possible issue could be within the door latch or sensor. If the panel is not reading that the door is closed it could be causing the dishwasher to stop and start. The sensor could also be sending false signals to the panel causing pause. You may want to seek assistance from a professional technician for proper diagnosis and repair. This will help to avoid any unnecessary part purchases. -Matt
Dec 20, 2014 | Frigidaire Dishwashers
How do I pause while recording? I can pause while playing back but can't seem to figure out how to pause a recording then resume, it just stops and starts a new clip. Please help. (My handycam is cano
The default is to start a new clip every time you press the stop button, but in settings you might be able to tell the camera to continue with the same clip provided you press record again with a set time. Not sure why you want to do this though - it's much easier to edit using small clips than very large ones.
Aug 23, 2014 | Canon FS100 Flash Media Camcorder
How to restore default configuration
From the user manual:Feed and Pause self testperforming this self test temporarily resets the printer configuration to the factory default values. these values are active only until power is turned off unless you save them permanently in memory. If the factory default values are permanently save, a media calibration procedure must be performed.To perform a Feed and Pause self test, complete these steps:1. Turn off (O) the printer.2. Press and hold FEED and PAUSE while turning the power On (I)3. Hold FEED and PAUSE util the first control panel light turns off.the printer configuration is temporarily reset to the factory default values. No labels print at the end of this test.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
The picture on the tv is shaking and pausing/freezing for seconds at a time.. and discolored but no signs of permanant discolor like a cloud on the tv screen.. what could cause this?
This seems like an internal problem, and can only be solved by an experienced television troubleshooter, I suggest taking it to a professional.
Mar 11, 2011 | Sanyo DP32648 32 in. LCD TV
Phillips 50P8341 will stay on about 15 mins then shuts off then the power button flashes twice, pauses then flashes twice again...
Seems like it is overheating. Try cooling it down by using a fan to blow air into it (temporary fix). Make sure the TV is well ventilated and heat can escape (permanent solution).
Jan 15, 2011 | Philips 50P8341 50" Rear Projection...
Permanent pause
It might be that the memory chip is fryed and it thinks that you are hitting the pause button, or eather it is that something is caught in the pause button. Take it a part or find something that will fit in between the pause button and clean it.
Jul 14, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
129 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
