Question about Craftsman Garden
I have a used Craftsman 25 HP, 48" deck, 917.272264. When I parked it in the fall it ran great, although reverse was always hard to push down. Now this spring it started right up and everything works except when I push on the forward or reverse pedals I get this awful undescribable noise and it goes no where. I did notice that the reverse pedal does not seem to return to it's up position very well if at all. All the belts look good and the idler has tension on the belts and moves. I moved the transport bar in and out and it makes no difference, the rear wheels are locked up. Also the cruise lever doesn't budge. Are these all related? Thx Tim
SOURCE: Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Posted on Oct 14, 2008
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
  • 246 Answers
SOURCE: runs but will not go
Hello brookspiercy:
From your Description it Sounds like a New Belt is Required and Possibly a New Clutch Idler Arm or Idler Pulley. The Grinding Sound like it May be the Bearings of the Clutch Idler Pulley.
>>For Better Assistance,
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
wadembly
  • 513 Answers
SOURCE: tines go around but wheels are locked in position and won't move
the gears in the transmission are possibly worn out if i can further help e-mail wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
When u push on the pedal for foward or reverse it seems like it doesn't want to pull like it use to and when u set the deck height it's a lot shorter than what it should be any suggestions It's a john...
you may have to reset the wheels on the mower deck to a higher setting. it sounds like the reason it is having a hard time moving is because it is set to low and is bouging down the mower.
Jun 09, 2014 | Garden
My craftsman 20 hp automatic lawn mower kills when i try to back up
It may have a safety lock on it causing you to not use the blades in reverse. My 07 craftsman has that safety feature.
Apr 13, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a craftsman 48" riding lawn mower and when I was mowing I ran over a piece of rope which got stuck around the spindle. I have tried to remove the rope but am not having much luck. Is there an easy...
There is usually no easy way as the rope goes really tight, The best thing is to use an old bread knife with a wavy edge to cut it off.
The hardest thing is getting to it, if you are up to removing the deck and turning it over, that is the best way.
Aug 22, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Tractor want move
safety on the seat if the blades were still lowered it will shut down the motor. have to disengage the pto.
Jul 19, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mower starts, but won't move
I would first look at the drive belt for damage or to see if it has derailed.
May 16, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
May 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 13 hp lawn tractor slipping in reverse and low gears
Really hard to say without looking at it but it sounds like a pully has seperated or is trying to come apart they are made in two peaces.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
32 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
