Question about Audix D6 Professional Microphone
The XLR came apart
Anyone know where the red, white and yellow cables attach to on the circuit board on the XLR?
    President:
  • 1,851 Answers
The ground (shield) is connected at pin 1. I think that it's the white color cable.
The "in phase signal - hot" is connected to pin 2. It's the red color cable.
The "out of phase signal - cold" is connected to pin 3. It's the yellow color cable.
Your microphone is a dynamic one so there is no need for power supply and no worry about wrong connections.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 09, 2010
My Mackie SRM-450's both make excessive white noise, one of them crackles quite loudly.
This type of active speaker by Mackie has a issue with operational amplifier ic's inside, they are just those little black things with 8-pin soldered to the pcb, you may have some of them damaged, because of the erratic operation of the units, let me know if i can help more.
Jul 04, 2013 | Mackie SRM-450 System
Literally, I woke up this morning and my 360 won't produce HD video. It was fine when I used it yesterday. I tried a new HDMI cable but nothing, though the standard Red/White/Yellow cables work fine....
ye what it is is you either have a bad solder point on your board or the board is defective there can be no other reason i can solder your board for a fee but there is no point mate when you can use the switchable lead and use the blue and green hd bits that are the same as the yellow and red and white ones and just put the switch to hd then you will have just the same quallity let me know how you got on m8
Jan 15, 2011 | Microsoft Xbox 360 Console
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
Wires came loose of control unit from circuit board do you know what order they should be soldered back green white and yellow wires are still connected but I don't know where/which terminal to...
maybe we can help each other out with the questioni have my white black and red still connected but the purple blue yellow green and brown cables are un soldered if u look at the transmitter with the buttons on the bottom and the screen at the top the wires should be on your right there should be nine spots strating from the bottom to upward skip 1 next one should be white then skip one next should be red then next one is black and then thats all i have hope we can help each other
May 15, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
UNABLE TO CONNECT IPOD TO TV
You need a converter for this one end is a headphone jack the other to plug in to your tv...you only having a red and white cord already covers you sound and video
Sep 15, 2009 | Apple iPod touch
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
Rel Q50 SPEAKER
This is very easy. The Red and Black(Sometimes white) are for your Audio Usually Left and Right respectively. Yellow is for Video let me know if that helps. there are some instances where if you plan to hook it up to a Television, specially the older ones, you'll find that you just have two inputs for only two cables so what do you do then. Well... Just hook up the yellow for the Video Par and Either the black or Red leaving one unused. Let me know how that works out for you alright. And feel free to ask more questions where we will be more than happy to assist you.
Oct 02, 2008 | Audio Players & Recorders
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Audix D6 Professional Microphone Logo
165 people viewed this question
Top Audix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Audix Audio Player and Recorder Expert? Answer questions, earn points and help others
