Question about Sony KP-51HW40 51" Rear Projection Television
42" sony projection with blurry picture
42" sony projection tv very blurry - used to only be blurry for first 20 to 30 minutes after turning it on but now its blurry all the time - pls help!!
Or try manually turning the focusing lens in the tv. you can reach it by removing the front of tv or pop off the ports on the sides of tv and reach your arm in there.
Posted on Feb 03, 2015
  • Sony Master
  • 5,138 Answers
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
Posted on May 09, 2010
Hello, my sony wega 42"
Dear , i think its Physical Problem in your TV, if your projection Lamp is Ok , so then its a Picture Tube or may be its a Display Circuit Problem..
Jul 24, 2011 | Sony Televison & Video
Blurry picture
convergence problem...very common. An excellent TV, well worth repairing!
Jun 03, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Plasma TV Picture Periodically Blurry/Color is Distorted
This sound more like a cable issue. Also check the leads going from your cable box to the set/ If you are using component cables one of them may be loose.
Apr 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture is blurry after replacement the bulb.
Pull the bulb back out, check the lens, do not touch the glass if it has a smudge on it at all that is whats making the pic blurry, you also want to check the port with the bulb out, it may have dust in it, if so clean out the port before replacing the bulb, I am sure you know this but make sure the tv is unplugged
Jul 10, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blurry picture
Just a shot in the dark but the first thing i do when i get a blurry rptv in my shop is clean the mirror. Dust can accumulate and create a blurred image. You must be careful however as some of the mirrors are Front Surface mirrors and require special cleaning solutions/techniques. If thats the case using a damp cloth could ruin the mirror. I hope this was helpful.
Jun 05, 2009 | Sony Televison & Video
Hi there, i have a sony rear projection..green and red lights flashing with no picture, cant turn tv on, any idea, it was working fine yestedray
Unplug TV from AC outlet for 10-15 minutes and replug it back and power up.
Let me know how old is this TV and have you replaced its Lamp>?
Jan 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Picture very blurry with lines going accross screen
hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
thanks,
janex
Mar 31, 2008 | Sony KP-61HS10 61" Rear Projection...
Red screen
It sounds as though your Picture tubes are getting weak or theres a bad capacitor in the screen drive circuit. The only way to tell would be to call in a tech to diagnose this problem with his test equipment. A tv set is not a place for an unexperienced person to play with. Good Luck
Jul 29, 2006 | Sony KP-41T65 41" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
538 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
