Insignia D300 I donot get
Insignia D300
I donot get eny video on my monitor. my monitor says
SELF TEST G
CHECK YOUR PC
AND SIGNAL CABLE
MONITOR IS WORKING B
My email [email protected]
  • 1 more comment
  • parra31 Mar 29, 2008
    it bootsup ok, power lite ok, hard drive makes a single noise,
    2 fans work ok, flopy and 2 cd roms flash ok, the 3 volt battery is new. the monitor works with other computer. other monitor does not work with this computer. thanks for your help.
  • rlbambi Dec 10, 2008
    My monitor says do self test. We woke up one morning and it wasn't working. The computer won't boot up and sometimes the green light is on and sometimes it's not.
  • Anonymous May 11, 2010
    is your pc booting up ,powerlight on, hard drive lights flashing on and off ,is it making any hard drive noises, power supply fan running, any beeps etc
    this will help me to help you.
    Terry
    Sergeant:
  • 349 Answers
If the pc graphics settings is to high for the monitor,it may not work,
what you need to do is:
  • boot-up and go into safe mode by pressing F8,and select safe-mode, once the pc has finished booting
  • right click "my computer" icon on the desktop or go to start button then right click on "my computer"
  • click on "properties" at the bottom
  • the device manager will open
  • click on display adapter plus sign and un-install it.
  • reboot pc, windows will setup a default driver for the video and your monitor should work. (if the resolution was the problem).
good luck and don't forget to rate my suggestion
Terry
Posted on Mar 29, 2008
  • Anonymous Mar 29, 2008
    sorry that's for vista, for xp.
    between the device manager opening (system properties) and click on display adapter plus sign
    the 3rd and 4th item above ,you need to click on hardware tab, then device manager button
    terry
    Sergeant:
  • 318 Answers
Might want to check your VGA or Digital monitor cable also, they have been known to go bad or come loose.
Posted on Mar 28, 2008
  • Hollyecho Montgomery
    Hollyecho Montgomery Mar 29, 2008
    I would try a different video card.
SOURCE:
Dell gx270 not communicating with monitor. self test feature check is floating on monitor
This is a self check for the monitor. This self test means that the monitor is not getting a signal from your computer. Have you installed any video cards in this computer?
If its onboard video meaning you never installed a video card then your video card is bad. Try purchasing a video card and installing it in the computer and your problem should be fixed. I hope this helps you. Any other questions feel free to ask thanks.
Jun 23, 2010 | Dell OptiPlex™ GX270 PC Desktop
Monitor is on but screen is black. green light for switching it off/on does not do anything when pressed
Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 01, 2010 | Dell E173FP 17" LCD Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
Computer powers up, but monitor shows a self test
Your video output is bad. Either the video card, or the onboard video built into the computer. You need to swap out the card or add a card to bypass the built in video port on your computer.
Thanks and please take a moment to rate as fixya.
Feb 11, 2009 | Gateway 550GR PC Desktop
Screen suddenly went blank except for a self test box
well in order to get rid of the self test window from your monitor... check the cable that connects your monitor to system tower & reset the connection... becase that is the only possible cause of the self test showing up on your monitor...
" as the self test option only appears when there is no video signal going from your video card to the monitor...
Jan 18, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Computer not booting up
Could be one of two things:
1. Signal cable from monitor isn't hooked up. (either monitor end or computer case end)
2. Video card in the computer is damaged and not putting out signal. This is unlikely though as usually this will trip the motherboard into beeping when you turn the computer is turned on.
3.
Jan 15, 2009 | E-Machines eMachines Desktop PC
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Open Questions:
Computers & Internet Logo
246 people viewed this question
Ekse
Alun Cox
