Question about Acer X203H bd Monitor
It won't turn on. Worked yesterday, after some removal and replacement of cords, rebooting computer. I hate this thing. Could never let it go to sleep mode as it didn't wake up.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 09, 2010
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
My Panasonic PT-47X54J won't turn on at all
The power indicator should blink 1-5 blinks when it wont power up. If you let me know how many blinks your getting I can assist with the problem.
Nov 06, 2012 | Televison & Video
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
When I go to turn on my computer it will not power up. worked fine yesterday but would not shut down so I removed the cord and battery in order to re-boot. After I put the battery back in and power cord it...
From what i hear you say, it sounds like your hard drive may have crashed. they are really easy to repair, but all your date will be lost if you replace it. And dont freak out because im not sure if it is that with out looking at it, but if it did crash i hope you backed everything up.
May 02, 2011 | HP Compaq Presario F756NR Notebook
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Flashing orange light, third from the left on the front edge, left side. Just replaced the battery yesterday.....
I had same problem. PC wouldn't even start at all. New cord & battery.Computer repairman said- remove battery, remove electrical power (& unplug the cord from power source :) don't electrocute yourself), then press the start button for at least 30 seconds. I pressed it for about a minute. Replace battery & power, (don't forget to plug the cord into electricity again), and press start button. That resets something inside.
It worked!!!! I couldn't believe it. I almost gave it away before I called repair guy. Yikes. :)
Feb 17, 2010 | Dell Inspiron B130 Notebook
I have a HP 6500 wireless --- Can not print --- It says offline. It worked yesterday
Those hp wireless printers can be a pain. the simplist thing I can suggest is to turn the printer off. Turn back on and reboot the computer and the printer software on the computer should say your back online again. If not more drastic action is needed.
Nov 17, 2009 | HP Office Equipment & Supplies
Toshiba Satellite A305D-S6848 HAS NO POWER. NO LIGHTS COME ON AND I PLUGGED THE POWER CORD INTO ANOTHER TOSHIBA AND IT WORKS. NOT A POWER CORD PROBLEM. NO FANS RUN OR ANYTHING WHEN I HIT THE POWER BUTTON....
TRY TO REMOVE THE BATTERY AND JUST PLUG THE CHARGER ON IT AND ON POWER. SWITCH IT ON. IF IT TURNS ON THEN YOU SHOULD KNOW THAT YOU NEED A NEW BATTERY OR IF IT DOES NOT, TAKE IT TO A COMPUTER SPECIALIST TO CHECK ANY HARDWARES THAT ARE NOT FUNCTIONING.
THANK YOU
WONDER
Oct 29, 2009 | Toshiba Satellite A305D-S6848 Notebook
I have a 46" Shape LCD Aquos television that I just bought yesterday. The TV worked for about 3 hours and now I can not get it to turn on. I tried unplugging it, waiting 5 minutes, rebooting it, tested the...
Please pack the Sharp back into your car & get the money back. One thing I love about this website is how folks will talk about the historic/chronic problems of things. Don't even worry about fixing it. Run, don't walk, back to where you purchased it. Next, consult a "Consumer's Report" type of ezine & find a better model!!
Dec 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Voicemail
sounds like the voicemail is rebooting or was unpluged, make sure the call pilot is pluged in and the lights are on. i had a similar problem once and the power supply to the callpilot went bad. once i replaced it it came back up and worked fine.
Apr 06, 2008 | NorStar T7316E Corded Phone
Acer X203H bd Monitor Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
