Question about General Electric AHH40LL Dehumidifier
Unit ices up and does not defrost room temp above 65 degrees
  • General Elec... Master
  • 43,501 Answers
Dehumidifiersunit ices up and does not defrost - 2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on May 10, 2010
I am showing a HI on my current humidity/set humidity display what does it mean
The HI indicates that the current humidity is 90%+ in the room/unit. You should check if the filter is clogged. I've seen this message in dryer locations when the dehumidifier coils ice up. Check the coils (behind the filter) for any build up.
If this is a brand new dehumidifier, leave it on for an hour to see if it auto-defrosts. (A similar wait is needed if the room is cooler that 60 degrees F.)
If the unit continues to freeze up and the room is over 60 degrees, you may have a refrigerant leak in the dehumidifier. If it is still under warranty (5 years on the cooling system), contact Haier. The warranty service number is 1-877-337-3639.
The manual for the DE65EK is available here: www.haieramerica.com/downloads/dl/file/id/26/de65ek_manual.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Dec 24, 2012 | Haier DE65EK High-Efficiency ENERGY STAR...
Why is my dehumidifier icing up.
The room temperature is probably too cold, or there's poor airflow
Here's some info that should help you figure out what's causing the problem:
If the evaporator coil is frosting completely and evenly, the most common cause is that the room temperature is too cold. Most dehumidifiers are not meant to be used when the room temperature drops much below 70°F and certainly not below 65°F (depending on humidity). There are however some models called "basement" dehumidifiers which are.
Another possible cause on standard models is poor air flow through the unit. If the fan motor is not turning fast enough (or at all) or the evaporator, condenser or filter (if used) being plugged can also cause this symptom .
May 13, 2011 | Goldstar DH304 Dehumidifier
Ice Buildup on Model DE45EA.
60 is too low for most dehumidifiers...if you warm up the room a bit to 65 it will work...
Here is a tip that will help you with basic trouble shooting..
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 22, 2010 | Haier DE45EAL Dehumidifier
Have a wind chaser wdh running in my basement and it keeps icing
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 29, 2009 | Windchaser WDH928 Dehumidifier
Why would it not take water out of the air, it runs so long it creates ice on the outside of it. With no water in the bucket. its in the Basement its 52 degrees and the humidie is 84. what can i do to...
Room must be above 60.
Dec 28, 2009 | Whirlpool AD50J Dehumidifier
Have Whirlpool AD50USS - unit ran for over 24 hours in DRY mode but collected no water. Should have been water in bucket as basement smells musty.
Dec 28, 2009 | Whirlpool Dehumidifiers
Unit comes on compresor and fan run but not collect much water
Dec 28, 2009 | Kenmore 54501 Dehumidifier
Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
May 10, 2009 | Frigidaire FDL50R1 Dehumidifier
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
General Electric AHH40LL Dehumidifier Logo
152 people viewed this question
Top General Electric Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a General Electric Dehumidifier Expert? Answer questions, earn points and help others
