Question about Whirlpool Dryers
Why is my gas dryer not staying hot what would cause it
    President:
  • 1,218 Answers
Good day,
Multiple reasons a dryer refuses to heat. Try following this outline and use the tutorial if you need to access the front of the machine.
Here are items to check. You will need an ohm meter to perform some of these tests.
1. Make sure the gas is turned on to the appliance.
2. Remove the back cover of the dryer. In the center bottom is a small skinny white ceramic device, held on with one screw.
A picture of the item appears at the bottom of this explanation.
Remove one of the wires, and check it with an ohm meter. It should show zero ohms of resistance. If not, it is defective, and needs replaced. This device on your brand causes 80 to 90% of all no heat problems.
3. As well, there are 3 or 4 other thermostats in the area, either round or rectangular, with 2 wires going to them. Check all of them if needed. They should all check zero ohms.
4. To check the igniter, you will have to remove the front panel. A tutorial follows, on how to do that.
Locate the gas valve, on the left side. Follow it forward, you will see the 2 wires on a plug, and at the tip of the burner tube, the igniter itself. Unplug, and check the igniter leads. It should read about 20 to 30 ohms. if not, it has burned out and needs replaced.
5. On the gas valve itself, are 2 black coils, held on with a 2 screw bracket. They can fail, but cannot be tested with a meter. If they are bad, the heating system will light the igniter, and shut down without firing the gas. All components must be in place to perform this test.
That covers 99.5% of all issues. There are others, such as the timer, heat selector switch, centrifugal switch in the main motor, but are extremely rare.
The tutorial below is not about heat trouble shooting, but is supplied to show how to gain access to the front of the machine.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Posted on May 09, 2010
2 Suggested Answers
mrbobfixit
  • 259 Answers
SOURCE: dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Posted on Jul 13, 2010
Will not stay hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Whirlpool LGB6300 Gas Dryer
Not staying hot
heatman101
Jul 18, 2011 | Dryers
My dryer wont get hot it just stays cold.
heatman101
Jul 10, 2011 | Dryers
When i turn on the dryer, the hot air only stay on for 15 mins,than come out only cold air
heatman101-=-
Jun 26, 2011 | Whirlpool LGB6300 Gas Dryer
The dryer only stays hot for a short time.
heatman101';
Jun 13, 2011 | Roper RGX4634KQ Gas Dryer
Our kenmore s70 dryer heats up but wont stay hot all lint is out,never a problem why wont it stay hot
heatman101
Apr 03, 2011 | Kenmore 72822Gas Dryer
Dryer wont stay hot to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 21, 2011 | Crosley CDG6000 Gas Dryer
Kenmore gas dryer does not get hot enough. Gas burner does not seem to stay on long enough. Model 110.72912100
heatman101
Dec 21, 2010 | Kenmore Dryers
Loud squeak and not staying hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Mar 07, 2009 | Maytag MDG6000 Dryer
Dryers Logo
247 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
