Question about GE GTS22KBP Top Freezer Refrigerator
Freezer quit working. The power is on. But no sound of compressor.
  • GE Master
  • 1,606 Answers
At the top on the control box , there is a hole about 1/2 inch in diameter . Find this hole and use a flat head screwdrive to insert and turn slightly . This is the defrost timer . The refrig could be stuck in defrost . If turning slightly and refrig starts , replace the defrost timer . If doesn't start , TAP on the thermostat knob and see if refrig starts . If so , replace the thermostat .
Posted on May 09, 2010
Testimonial: "The solution was right on target. That is exactly what was needed and it corrected it."
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Hums seconds only does not freeze
If it hums then quits and hums and quits and just keeps doing this then either the compressor start relay is burned out or the compressor is seized. Unless you are capable of diagnosing this you should have a tech check it out. If it's just a relay they are relatively cheap, but if it's the compressor it could cost more than the freezer is worth.
Dec 03, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
The freezer quit working has power to theunit tryed turning it up it acts like a fuse or a relay the compressor is hot to the touch the compressor tuns on amin or so then turns off
If you hear a buzz or clicking sound, your compressor may be locked down, check warranty some have 5 year warranty on sealed system repair, parts and labor
Aug 27, 2010 | General Electric Upright Freezer...
My Refridgerator/freezer is not working
Sounds as if the compressor is not running even tho the fans are. The overload relays on the side of the compressor are usually the source of this problem. They are on the side of the compressor and if you change these out you should be fine. Fairly easy to do as it should just be a plug connecting it. Hope this helps.
Feb 21, 2010 | Maytag MTB1953HE Top Freezer Refrigerator
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
Jun 02, 2009 | Refrigerators
Freezer has defrosted itself, refrigerator not holding cold
The clicking sound is from a bad start relay on the compressor or a bad compressor.
Replace the start relay. It is relatively inexpensive.
If that does not correct the problem the compressor will have to be replaced.
May 24, 2009 | Whirlpool ED5VHGXM Side by Side...
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refridge and freezer stopped cooling
it is either the start switch on the side of the compressor or the compressor itself.
the buzzing sound is the start switch trying to start the compressor and the click is the overload on the start switch kicking it out.
the start switch is bad or the compressor is pulling too much amps = bad compressor.
Jun 28, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Cold tech commercial reach-in freezer
sounds like an issue witrh the microprocessor to me as well, although you tried bypassing it it still didnt work its quite possible that the fan aand compressor are runnig on different voltagfe the 110v , new energy effient compressors are starting to run w/ 220, an inverter built into the circuit board could be steppin up power,
Apr 08, 2008 | Freezers
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
GE GTS22KBP Top Freezer Refrigerator Logo
178 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
