Question about Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo
Using TV as monitor - resolution difficulties.
I've had this TV - Magnavox 26MD357B with built-in DVD player - set up as a monitor using a VGA cable to my computer for several months now. Even when I upgraded to a much newer, much better computer, it worked flawlessly. However, I recently changed cables from VGA to HDMI. Upon doing so, I found that the resolution had suddenly expanded past the "boundary" of the screen and had been set to 1920 x 1080. A rudimentary web search indicated that the proper size was 1366 x 766 but setting it to that size made the screen so small that it failed to fill even one-fourth of the screen's space and I seem unable to find the size that fills the screen without overfilling it. Any assistance related to this matter would be very much appreciated. Thanks.
4 Suggested Answers
SOURCE: Fuzzy picture with DVI input from NVIDIA PC Card
I have the same TV and I found that increasing the DPI percentage (Dots Per Inch) you could reduce the fuzzy stuff, but in its still no where close to being the same quality as VGA. Hope that helps.
Posted on Dec 09, 2007
  • 1284 Answers
SOURCE: now using an hdmi to dvi cable - screen size has reduced
Your digital box should have aspect settings as well. When watching HD TV and or movies there is a possibility to get the black bars on top and bottom. It all depends on the ratio it was filmed in.
Posted on Nov 19, 2008
  • 352 Answers
SOURCE: Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Posted on Jul 14, 2010
I can't connect my xbox360 to my sony pfm-42b2 tv
Keep in mind that your Sony IS NOT A TV, but a monitor instead. There is an actual XBOX360 VGA adapter that's available at most gaming retailers. It was initially designed for those who wanted to use their PC monitors for there console gaming. HDMI is NOT compatible with a VGA input as HDMI is a digital signal type and VGA is an analog type connection. You must also remember to have the XBOX set to a NON-progressive resolution (480i) if trying to hook it up using the standard XBOX video cables.
Apr 17, 2012 | Sony Televison & Video
I want to use my television as a computer screen. How do I switch the television to proper mode?
Look for a button on the remote or the TV itself labeled Source or Input. This should let you change the input between TV, AV, HDMI (on some TVs), and PC. Just press the button repeatedly or use the up/down arrows.
Before setting the input to PC (VGA), turn off the TV and the computer. Then connect the VGA cable (M-M) and the audio cable (a 3.5 mm M/M cable, if you plan to use the TV speakers) between the two units. Next turn on the TV and set the input to VGA. Then turn on the computer. (This is if you are using the VGA or D Sub 15 connection.) For a desktop, if you do not have another monitor connected, the TV should automatically be detected and the resolution set with any Windows OS (XP and later). However, you may need to reset the resolution and the refresh rate. For Windows 7, right click on the display and choose Screen Resolution.
For a laptop, you may need to enable the video port in the BIOS. Accessing this depends on the manufacturer of the computer motherboard. (Often Esc, F1 or F2 is the key to press after turning on the computer but before the OS loads. This can be tricky to time correctly.)
With a laptop or a desktop with another monitor attached, you will need to tell the computer how to deal with the multiple monitors. (Extend, monitor 1 only (or laptop internal monitor), monitor 2 only (external monitor), or dual display.) For my HP laptop with Win7, I choose Graphics Properties instead of Screen Resolution. There may be a keyboard Fn shortcut to access this.
Some TVs will accept a PC signal on the HDMI port (directly from an HDMI port on the computer or via a DVI to HDMI cable). Not all TVs do this. (Without the model for your TV, I can't confirm if this will work. If it doesn't, it is because of the differences between the PC output signal and that of set top boxes (cable or blu-ray players).
I hope this helps.
Aug 18, 2011 | Insignia Televison & Video
I recently purchased a GADMEI external TV card. i used a VGA cable to get it run on my monitor. The problem is, i have a DVD player connected and when i turn it on, the screen goes black and says "out of...
It is saying out of range because the video resolution is too high for the monitor to display. What kind of DVD player you are using and how it it connected to the monitor?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href=""></a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href=""></a></span><br />
Aug 26, 2010 | BenQ E900 19 inch LCD Monitor
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
How do i connect my magnavox zv420mw8 to my cable boxconverterand modulator
the cable from the wall is to the cable box in....(do have monitor) cable box out to tv coax in...dvd / vcr & audio outs to tv ins....and tv outs back to dvd vcr audio is on ch 3 for cable...look for your dvd /vcr or aux ch when want to look a dvd or set the dvd to ch 3 settings and cable broadcast...your cable box will determine what you record....note HBO may not record on DVD, but will on VCR tape
May 15, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Mar 25, 2009 | Bose 3 2 1 GSX System
While connected via VGA cable Viewsonic VG920 Monitor has an error stating "out of Range" . H. Frequency 157 Khz V. Frequency 59.8 Khz
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
Dec 13, 2008 | Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/...
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Pc and lcd tv
that's really easy. just plug in a VGA or DVI cord from the PC to the Sova TV (those are both regular cables that normally would go the computer monitor). then press the source button on the remote (not too fast, it takes a second to detect the signal), until you see VGA or DVI, and your computer screen should show up. use the display settings on your computer to get the best resolution on the tv. depending on your computer, you may have a program that can save different screen resolution profiles for you (since the Sova TV resolution and the computer's optimized resolution using a different screen (such as the built in screen on a laptop -- or a different monitor with better resolution than the Sova TV), this way you can easily toggle between settings depending on what monitor you use.
Jul 29, 2007 | Sova DSV32P112 32 in. LCD Television
Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
