Question about Cooktops
Necht Gas Hob Ignition is not working
I have a Necht Gas Hob recently installed but the ignition to lit the hobs is not working. There is no 'clicking' when I press the buttons. I have checked the electrics and the power is running through to the hob okay.
Eddie Rentas
  • 59 Answers
SOURCE: hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
  • 2976 Answers
SOURCE: four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Posted on Jan 04, 2009
SOURCE: creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Posted on Apr 11, 2009
heatman101
  • 43501 Answers
SOURCE: electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
heatman101
  • 43501 Answers
SOURCE: ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
What type of pipe do i need to by for connecting necht gas hob to my gas
Usually it is a flexible pipe with a gas clip connector on the wall end and a standard thread on the cooker end. In the UK we employ Gas Safe technicians to install gas appliances due to leaks and possible explosions caused by an unsafe installation.
Feb 04, 2017 | Cooktops
CDA gas hob ignition
try the fuse ..
Dec 27, 2013 | Cooktops
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Electric ignition to hob seems to be jammed
heatman101
May 31, 2010 | Cooktops
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Ignition not firing on a neff hob, gas fine
heatman101
Feb 22, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Sparking ignition
switch Is stuck in on position
Apr 15, 2008 | Tecnik 27 in. TKH3515SS Gas Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Cooktops Logo
101 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
